02-26-2014, 03:56 PM | #1 |
Rep 36
20 inch wheels for 4 series
I was wondering if this size 20 inch wheel will fit ok on my 428i M sport lowered on H&R supersport.
Front: 20×8.5 30 offset Rear: 20×10 38 offset If these will fit without rubbing issues what tire size is recommended that's not too aggressive? Thanks in advance. |
03-03-2014, 11:17 AM | #3 |
Rep 12
Drives: 2k10 LCI E90
I think 20" are to big. The 19" should be just fine if you are lowering your car. Doing 20's w/ lowering would mean you may have to change your suspension set ups. (which I dont know to much about) lol I had 20's on my E90, then with all of the rubbing and flats. I had a flat every 2 to 3 months. I'll never put 20's on a Bimmer again.
03-03-2014, 11:31 AM | #4 |
83
Rep 155
That should fit fine. I am running 20x9 with 35 and 20x10.5 with a 45 and rear still has a bit of room. Just depends how low you are going to determine tire size as you can run a 30 series or 25 in the rear.
F32-M4 CONVERSION,STANCE WHEELS, KW SUSPENSION,DOWN PIPE AND FULL IPE VALVETRONIC EXHAUST. M PERFORMACE CARBON FRONT END.
03-03-2014, 12:04 PM | #5 | |
Rep 1,555
03-03-2014, 06:34 PM | #6 |
2052
Rep 25,988
Not definitive since we haven't mounted wheels on a 4-series quite yet.. but if fitment is anything the like previous gen 245/30/20 285/25/20 should work.
VMR|Wheels | 714.442.7916 |
sales@velocitymotoring.com | www.velocitymotoring.com | facebook | flickr | Instagram |
03-03-2014, 06:36 PM | #7 | |
Rep 1,201
Don't expect e92 3 coupe wheels to fit though. The offsets are way less aggressive and the wheel well is overall smaller compared to last gen. |
03-04-2014, 10:44 AM | #9 |
Rep 6,811
Drives: E82 135i / E92 328i / E60 550i
20s look great on a 4 series. I have done a few 20 inch setups on the 4 series and I love them. Run a 245/35/20 and a 275/30/20. What wheels are you looking at?
03-04-2014, 10:28 PM | #10 | |
Rep 1,004
Fitment is on Point with H&R Sport Springs and 20" Wheels. Take a look at the setup on this white 435i. Wheel Specs: Vossen CVT F:20X9 R:20X10.5 |
