03-11-2014, 08:15 AM | #1 |
Rep 923
DIY: MPPK intake silencer mod
I had read that the MPPK intake was ever so slightly louder than the stock intake, but at over 300$, I thought it was ridiculous for a piece of plastic identical to the one already in my car, but with a hole cut into it.
So I took it upon myself to drill out a few holes into the stock OEM intake to recreate the perks of the MPPK intake. Tools required: - Flathead screw driver - Step drill bit Here's what the MPPK intake silencer looks like, with the parallelogram shaped red hole. This is the part you want to get to and modify: Step 1: Loosen the clamp, but do not take it off. Step 2: Remove vacuum hose by squeezing the tabs and pulling it out, be careful it's fragile. Step 3: Remove the sensor clip. Step 4: Undo the 4 retaining clips. Step 5: Pull up on the intake pipe to release it from the rubber attachment in the middle. Step 6: Rotate the intake pipe up and out of the way, just to give you enough room to access the filter and intake silencer. Step 7: Remove the OEM filter. Step 8: Pull up gently on the intake silencer, it doesn't take much strength at all. Step 9: Drill holes to your liking. Step 10: Reverse steps to reinstall the now modified intake silencer. I know some people might not be a big fan of this mod, but honestly, it costs nothing and provides you with pretty much the same benefits the MPPK intake does. Intake sound is increased by 5-10%, so it's very subtle. Pretty much exactly what I was hoping for. There is enough room to drill a third row of holes, but I decided to stick to this. Comments and criticism welcome
GONE: '13 335i X-drive ///M-Sport | GONE: '16 340i X-Drive ///M-Sport | GONE: '18 540iX-Drive ///M-Sport | NOW: '20 X3///M
03-11-2014, 10:34 PM | #2 |
2006 TIME Person Of The Year
9720
Rep 6,445
When I remove my front bumper cover to remove the ACC sensor's visible stickers, I'm also removing part 15 from the intake. That mesh looks like it's only 50% open! Maybe I'll add one of those scoops behind the grill while I'm at it... :
03-11-2014, 10:46 PM | #3 |
Rep 923
Was thinking about adding one of those scoops as well ! Should help with airflow that's for sure. Not sure id remove part 15 it's meant to keep larger debris out, especially with the scoop I'd want to keep it in there ever more.
03-12-2014, 06:55 AM | #4 | |
9720
Rep 6,445
1. There is still an air filter between the opening and the engine. 2. I had a much more direct opening in a past vehicle and it wasn't an issue.
03-12-2014, 07:23 AM | #5 |
Rep 923
Good points, I think I might get that scoop and remove the filter, should increase air flow.
07-07-2014, 06:55 AM | #7 |
Rep 923
Possibly, but I think it hardly makes a difference. Results in a sportier sound pretty much.
04-26-2019, 03:13 AM | #10 |
59
Rep 231
10-14-2019, 02:35 PM | #11 |
Rep 288
Put holes around the entire air box and it sounds pretty good. Just make sure you're doing it BELOW the filter. I'm probably gonna get a CTS Intake eventually but this was a cheap alternative if you just want a bit more sound, highly recommend
11-17-2019, 09:09 PM | #12 |
Rep 5,406
In case anyone reads this old post- the M Performance intake (in the bottom of the plastic airfilter box) has an extra hole trimmed in red plastic that is in the front of the box so it is actually pulling cooler air coming in from the front grills of the car. That's the exact same spot to drill or cut holes.
waxwing_f311.50 |
04-08-2020, 12:40 PM | #13 |
BMW CCA Member
491
Rep 808
Yep just did this, this week. Took less than an hour. I used a 1/2" drill bit and marked 3 columns by 3 rows of holes.
I did my holes in the same place as the MPPK inlet. The MPPK red inlet sits right behind the driver side headlight by about an inch. It also picks up some cold air from the right-most bumper vent. I also had the "snow" vent on my 435i. I popped that off too. It may pick up a little heat from the motor, but it faces the what looks like the AC unit... but it's also the cold side of the motor, so not a lot of heat. Can't say it's a massive pick-up in power or sound. I do hear the turbo a bit more. But it's like going from volume 1 to 2 on a speaker. I do think from doing this, I'll be replacing the air filter more often though! As an aside, when you guys did this, was the increased sound with the stock filter or the K&N/AFE filter? I think having a little more intake noise would be nice. |
04-11-2023, 05:31 PM | #14 | |
18
Rep 42
I just dealt with this; I did a similar mod and the K&N filter was popping 2 codes (P00BD for MAF and P0171 for LEAN CONDITION). I ended up returning the K&N filter. Running paper for now until my CTS intake shows up. I did proper troubleshooting, wasn't a vac leak, wasn't improper installation. The MAF and stock tube just doesn't like the K&N+MPPK lower airbox/mod. MY GUESS is because of the panel filter design; when you're ramming air into the box, the only place that air has to go is past the air filter, so if you drop in a high flow air filter, all that air rushes past the MAF and throws off its numbers. With a paper filter, it's thicker/dense and provides a resistance to the ram air, hence no codes, BUT, less sound. AGAIN; just my guess. I'm totally new to the turbo BMWs and DME stuff. As someone said in a previous post; just the MPPK/mod is like turning the volume to 2/10. Add in a high flow air filter and it's like turning up to 3-4/10. This is going off of 1 as being stock/muffled/almost zero turbo noise and 10 being an intake like MST/CTS/Injen. I started a thread a couple days ago and someone confirmed that MPPK+AFE has worked well for them and others, and they don't believe it's an air ram issue, instead it's an air flow issue with the K&N just being way too "flowy". Last edited by junlikesf30s; 04-11-2023 at 05:43 PM.. |
