11-23-2015, 09:50 AM | #1 |
Rep 86
First 1/4 mile run with the 135i
I went to Capitol Raceway yesterday and got a few "baseline" runs. Car is bone stock except for a Cobb Stage 1 flash. Let me know if this is good and what I can improve on. Car is an automatic with the Msport package.
12-03-2015, 03:40 PM | #2 |
14
Rep 100
Looks like a solid time and trap speed. Did you start in second? I heard that helps with the launch. You might be able to bring that 60 down. I didn't know the track was still open. I might try going soon then
12-03-2015, 04:00 PM | #3 |
138
Rep 253
Drives: 2013 128i LE
Looks like a good run. I will be picking up a low mileage 09 135i AT M-Sport in June and plan to have fun with it at the local track too. Already looking at upgrades...
What made you go with the Cobb vs JB4?
// '13 BSM 128i Limited Edition //
12-09-2015, 09:33 PM | #4 |
Rep 86
I started in 1st for all of the runs. I should try starting at 2nd next time up it might help with the 60. I figured also this would be the best i could get given that it was mid 40s that day on the stock run flats
12-09-2015, 09:34 PM | #5 |
Rep 86
I went with Cobb just because it is easier to install and I've had experience with it with my previous car, Mazdaspeed3.
12-15-2015, 12:08 PM | #7 |
Rep 86
12-20-2015, 08:22 PM | #8 |
21
Rep 330
Every time I try to do a 0-60 run, I always get killed by that stupid lag from the drive by wire system in my DTC. (around a .5-1 second delay when accelerating from a stand still)
Still can't get rid of it with the transmission software update or resetting the adaptive throttle stuff... |
01-03-2016, 09:45 PM | #9 |
Asleep
53
Rep 298
That's a pretty good baseline, op. My ETs were in the 12.7-8 range at 112ish when I was running basic bolt-ons (OTS Cobb tune, intake, intercooler, & downpipes).
2007 C6 Corvette... VaraRam intake, FAST 92 IM, AI ported stock heads, Cam Motion cam, TSP headers/x-pipe, Borla S-Types, C6Z differential - 425whp
2008 135i... VTT S2+, MOTIV PI, FBO - 582whp (sold) 1999 C5 Corvette... Blackwing intake, C5Z titanium exhaust - 344whp (sold) Others sold: W204 C350, E90 330i, W-body Monte Carlo SS, etc. |
01-10-2016, 09:40 AM | #10 |
Rep 86
Thanks man. 12s isn't bad either on your run. I figure that with a better set of tires and traction i should drop that 60ft down to around 1.8 and hit mid to high 12s
01-10-2016, 06:19 PM | #11 | |
Asleep
53
Rep 298
Tires and e85 are the biggest difference makers in my experience. I went back with the only difference being NT555Rs and an e48 tune and managed an 11.9x @114mph on a soft 1.9 60ft. Promptly blew my stock turbos that very night haha.
02-02-2016, 09:19 AM | #12 |
83
Rep 394
WOW! Some nice times here!
My car bone stock N55 hit 13.7 @ 103MPH. This was with the stock runflats and my first time at the track! I tried launching it 3 ways and all ended up around the same. Tires are limiting me, spun too much. Temperature outside was 7C and track was slippy, launches weren't grippy unless i rolled into it slowly |
05-03-2016, 07:09 AM | #13 |
12.92 @ 173.0km/h - 1.84 60'
Rep 36
I think you have a solid 12 second pass with a good 60' time.
Our 2009 ran a best of 13.48 @ 100mph on factory run flats with 1.9x 60'. Change to Kumho KU39 265/35/18 tyres put times back to 13.6 @ 99mph. Recently fitted JB4 and DCI and was pleasantly surprised to drop to 12.9 @ 107mph with a couple of 1.84 60'. 60' times achieved by bring engine up to ~2,000rpm on the brake and bouncing in. |
05-28-2016, 12:30 AM | #14 |
83
Rep 394
Just came back from 1/4 mile strip, did 13.2 @ 107MPH. Jb4 Map 5, Charge pipe, Intake, N55 engine. Michelin pilot super sports
It was 90F however with 60% humidity. So im happy with what i did! Clutch did start to slip on the 6th run tho, so i stopped after that |
05-28-2016, 01:25 PM | #15 | |
40
Rep 116
2015 Estoril Blue 6-Speed M235i
10-08-2016, 08:54 AM | #16 |
Rep 86
I'll most likely be hitting the strip again this coming friday depending on work schedule. Now with DP and FMIC and Stage 2+ on the COBB OTS. So we'll see.
