07-04-2014, 01:39 PM | #1 |
BMW Enthusiast
106
Rep 1,034
Need Help: Planning to run square setup of 235/40/18 et45
Hi guys, I bought Apex Arc-8 hyper black 225/40/18 et38 - 265/35/18 et62 (Bridgestone Potenza RE-11) about 6 months ago and planning to run a square setup few months from now.
My choice of wheels will be OZ racing leggera HLT 8x18 et45 and I plan to pair it with 235/40/18 Michelin PSS all around. Do you guys think wheel spacer will be necessary to make the front setup rub free? If yes, should I run 3mm or 5mm? Currently I'm running stock sport suspension but will lower the car on Eibach Pro-kit at the same I install the wheels and tires. For the rear setup, will it look flush without any spacer? If not, which spacer size should I get? Beside that setup, I might consider to run 245/35/18 square setup on Michelin PSS as well. Do you guys think it will fit fine since the width of the rim is 8 not like other usual width of 8.5? Really appreciate thoughts and opinions from you guys! This is just another small project that I promise to myself when I get a job in next coming month. Thanks guys, CL
2011 JB E82 135i - Premium pack | Value pack | Premium sound | Sport pack | M-Sport steering wheel and suspension | Blackline LCI tail | BMWP carbon spoiler | BMWP CF license frame | BMWP gloss black grilles | Meisterschaft GT w/gloss black tips | CF diffuser | CF splitters | Hyper Black Apex Arc-8 w/Potenza RE-11 | Dinan camber plates
07-05-2014, 10:20 AM | #2 |
Asleep
53
Rep 298
I'm running 235/40r18 Pilot Sport A/S 3s on v701s (18x8.5 et45) and I only get slight rubbing on the front fenders when I hit real nasty dips. 245s are a no go without any work.
2007 C6 Corvette... VaraRam intake, FAST 92 IM, AI ported stock heads, Cam Motion cam, TSP headers/x-pipe, Borla S-Types, C6Z differential - 425whp
2008 135i... VTT S2+, MOTIV PI, FBO - 582whp (sold) 1999 C5 Corvette... Blackwing intake, C5Z titanium exhaust - 344whp (sold) Others sold: W204 C350, E90 330i, W-body Monte Carlo SS, etc. |
07-05-2014, 01:06 PM | #3 |
BMW Enthusiast
106
Rep 1,034
Do you run wheel spacer? I believe 235/40 will be very close if not touching the inner strut. I'm currently have Dinan camber plate to keep the camber -1.5 all around and prevent rubbing on my aggressive setup. I'm planning to get 3mm spacer when I installed that 235/40/18 PSS. Do you run stock suspension or aftermarket? Thanks man!
07-05-2014, 01:19 PM | #4 |
Asleep
53
Rep 298
My suspension's completely stock, no spacers. My tires actually rub on the fenders, with good enough clearance from the struts. I was tempted to run 245s, but I didn't want to spend more money lol. Good luck, man!
07-05-2014, 02:05 PM | #5 | |
BMW Enthusiast
106
Rep 1,034
It was pretty PITA when I installed my 8.5x18 et38 with 225/40/18 up front. Almost rub eveytime I hit a bump, dip or uneven road but all the problems solve with Dinan plates. Thanks man!
07-06-2014, 01:58 AM | #6 |
232
Rep 2,643
I'm confident you will have more than enough space on the strut side. Because you are using 8" wide front wheels you have an extra 6mm clearance over most people with 8.5" wheels. If you change to coilovers, then you might need to run a spacer to clear the tire, but OE style struts aren't that wide. I guess you will have close to 10mm gap between the tire and the strut.
07-06-2014, 02:04 AM | #7 | |
BMW Enthusiast
106
Rep 1,034
07-06-2014, 02:54 AM | #8 | |
232
Rep 2,643
07-06-2014, 03:02 AM | #9 | |
BMW Enthusiast
106
Rep 1,034
07-06-2014, 03:21 AM | #10 |
232
Rep 2,643
There is a thread:
http://www.1addicts.com/forums/showt...php?p=15038360 |
07-06-2014, 04:17 PM | #11 |
BMW Enthusiast
106
Rep 1,034
Thanks John! Just curious if I can fit Volk TE37 that has et35 on 8.5x18 for rear setup. I find a good deal for whole set of Volk TE37 but on aggressive setup.
07-06-2014, 05:14 PM | #12 |
Rep 4,531
Eek. ET 35 is too aggressive in the rear
I run 18x8.5 ET40 with 245 Dunlop ZIIs. I have -3.6* Camber up front, -2* in the rear. 5mm spacer up front. Had to roll both fenders, and lowered quite a bit. |
07-06-2014, 09:04 PM | #13 | |
BMW Enthusiast
106
Rep 1,034
Do you rub on the rear even though on -2 degree camber? I'm speaking without rolling the fender. I'm just wondering since your ZII setup is wider than my planned setup. Let me know what do you think. Thanks Man!
07-07-2014, 06:59 AM | #14 | |
Rep 4,531
I don't think you're going to fit ET35 in the rear. Your wheel is going to be 5mm more than mine...and mine is a VERY tight fit |
07-07-2014, 08:51 AM | #15 | |
Rep 6,478
Quick question: Do you get any rubbing under lock with 235s up front? A full left hand lock on 225s rubs justtt a bit on the oil cooler's plastic louver piece, just so slightly. Hasn't left any marks on the tire or caused any visible damage to the plastic piece - but i'm worried 235s would be too much. I know without seeing my car's ride height it's tough to offer more than an educated guess.
F30 N55 XDrive EBII |
07-07-2014, 08:56 AM | #16 | |
Rep 4,531
And no, no rubbing at full lock...because 128i and no oil cooler Picture of car to reference how low I actually am under compression load: |
07-07-2014, 08:59 AM | #17 |
Rep 6,478
Doh totally forgot you drive the 28, my bad! Yea I have a bad feeling 235 would start to make substantial contact with the oil cooler mesh...It's just a soft plastic screen but still i'd rather avoid it.
This platform is so limiting in terms of tires. Frustrates the hell out of me. How nice would a 255-275 setup be
07-07-2014, 03:01 PM | #18 |
BMW Enthusiast
106
Rep 1,034
I have one more "hard" question guys, just found a set of Volk TE37SL wheels at very reasonable price. The spec is 8.5x18 et35 (I know its a 3 series fitment) and I plan to run square setup with 235/40/18 Michelin PSS.
I'm pretty sure I can fit it upfront with correct amount of camber since now I'm running 8.5x18 et38 225/40 RE11 and I can fit it with -1.5 camber. The hard thing will be the rear setup. My car is completely stock and if I can fit those wheels I'm looking into possibility to lower my car by lowering spring. Let me know guys! Thanks
07-07-2014, 03:26 PM | #19 | |
Rep 6,478
ET35 on the rears is quite aggressive. Your fenders won't be happy, let's put it that way.
07-07-2014, 03:33 PM | #20 | ||
Rep 4,531
07-07-2014, 03:42 PM | #21 | |||
BMW Enthusiast
106
Rep 1,034
eibach, et45, oz racing, spacer, square |
