07-18-2017, 07:56 PM | #1 |
Getting Risky ;)
99
Rep 57
MCShred "Build" Thread
Hey Guys, Im fairly new to the forum but have been quickly putting together my 1er through the help of your posts. My 2010 128i (N51) Space Grey came with the Sport Package, 6-Speed Manual, Black Leather Interior, and Xenons. I have already installed 12mm BMS Spacers all around, CDV Delete, Active Autowerke Exhaust, and AFE Stage 2 CAI. I have Active Autowerke Headers currently getting coated at Swain Tech... I have plans to do an extremely clean build all around. I plan on doing suspension,performance brakes, and wheels ASAP after I get the headers installed and the car all tuned up! Let me know what you guys think
07-19-2017, 01:42 AM | #2 |
E82 Mudflap Ambassador
2216
Rep 2,219
Drives: '08 128i
Grey manual sport 128i? I'm gonna be following this like a hawk.
My 2008 128i - Sparkling Graphite/Beige - Sport pkg - 6MT - Click me!
Parents' 2014 528i - Mineral White/Ivory White - fully loaded Instagram @Andreys_128i and @Honda.Bito |
07-19-2017, 08:58 AM | #4 |
Getting Risky ;)
99
Rep 57
I did order the AA tune with the headers to try out first, I do have access to a dyno and will be posting up the numbers after the install and tune. Still deciding between KW V3's or Ohlins R&T for suspension. I want to do a bigger brake set up but still deciding on what to get
07-19-2017, 09:01 AM | #5 |
Getting Risky ;)
99
Rep 57
desertman1232215.50 |
07-19-2017, 01:17 PM | #7 | |
Rep 9,004
Any reason why you chose the V3 or R&Ts? I thought the R&T's spring rate was too low, and the V3s have Progressive springs? |
Phil@BPC467.00 |
07-19-2017, 01:57 PM | #8 | |
Getting Risky ;)
99
Rep 57
I always here nothing but good stuff about the R&Ts. Still have time to decide about suspension, still doing more research. What would you suggest for spirited driving and an occasional track setting? Last edited by MCShred; 07-19-2017 at 02:02 PM.. |
07-19-2017, 02:23 PM | #9 | |
Rep 1,233
You should talk to Harold @ HPA, he has a ton of experience and can help walk you through options, and they are a good vendor from everything I've read/heard (I'm not affiliated in any way, have never even bought anything from them). TC Kline has some nice stuff for these cars also...like I said, tons of options. |
Taskmaster2470.00 |
07-19-2017, 02:32 PM | #10 |
2216
Rep 2,219
Drives: '08 128i
http://www.e90post.com/forums/showthread.php?t=1329840
Valvetronic lift mod. Good for squeezing that very last bit of performance out. Also since you're manual, consider the auto diff 3.73 swap (or even a regeared LSD)
Rallysmurf84.00 |
07-19-2017, 02:49 PM | #11 | |
Rep 9,004
The valvetronic lift mod just adds more effective lift to the intake cam at 80% throttle or more - but you need a tune. The .5mm increase was good for 8whp - I have the 1MM http://www.e90post.com/forums/showpo...&postcount=240 And I second the opinion of calling someone experienced on picking a suspension - TCKline, Ground Control, or just talk to Harold at HPA and they will point you in the right direction. |
Phil@BPC467.00 |
07-19-2017, 07:25 PM | #12 | |
Getting Risky ;)
99
Rep 57
07-19-2017, 07:26 PM | #13 | |
Getting Risky ;)
99
Rep 57
07-20-2017, 01:00 AM | #14 | |
2216
Rep 2,219
Drives: '08 128i
I can't remember off the top of my head, but were any dyno runs for purely NA made for the valvetronic lift mod? Like stock motor, then motor with the lift/appropriate tune?
Phil@BPC467.00 |
07-20-2017, 01:27 PM | #15 |
Rep 9,004
AA doesn't have a tune for those. I sent BPC my personal set of the .5mm shims to make a tune from it, then they had a second 1mm set to use (from the supplier) to test on their turbo N52.
Without knowing what to modify, or not tuning it at all, they won't work. |
desertman1232215.50 Phil@BPC467.00 |
12-27-2017, 08:53 PM | #16 |
Getting Risky ;)
99
Rep 57
UPDATE: Headers are in place, replaced the water pump and thermostat while underneath the car...The headers sound great but haven't had a chance to drive with it yet...Having some issues with the idle of the car after uploading the tune and resetting the adaptations , it's surging like crazy Plan is to change the oil and put some miles on her and see if anything changes!
Eins Suchtig61.00 andrey_gta300.50 |
12-27-2017, 08:57 PM | #17 |
Getting Risky ;)
99
Rep 57
As a side note I had some wheels refinished and re-drilled by Jordan over at Sensei6.... insane quality... Cannot wait to get the suspension delt with within the next month or so!
12-28-2017, 01:12 PM | #18 | |
Rep 9,004
12-28-2017, 03:06 PM | #19 |
Getting Risky ;)
99
Rep 57
I know originally I was leaning towards the KWs or the Ohlins but I think I'm going to go with the Bilstien PSS10 Coilover with M3 LCA upgrades and Ground Control Camber Plates. Reseting the adaptations right now! Logged about 60~ miles today, very impressed so far with the AA Headers + Tune..
03-21-2018, 11:02 PM | #20 |
Getting Risky ;)
99
Rep 57
Tiny update: Aero bumper and side skirts along with other goodies are currently getting painted... Just received pictures from the powdercoater of the Calipers
