11-18-2018, 07:22 PM | #1 |
Rep 45
Looking for: Aux water pump install
I been searching but maybe I'm not searching for the right things. I'm looking for a DIY for the auxiliary water pump. I threw a code this weekend and it led me to:
https://www.m3post.com/forums/showthread.php?t=1415033 Thank you in advance! I was looking to work on it before the turkey is ready! Last edited by phichi1106; 11-18-2018 at 07:39 PM.. |
11-22-2018, 03:28 AM | #3 |
Driver
157
Rep 156
I have changed the aux pump last year,
because of the same error you have: 00A6D1 Partnumber is: 64118369806 You will finde the Pump near the Firewall of the Driversside (LHD). After you have removed the Airfilterbox you can see the pump. Remove the connector on top and the two waterhorses (i used two clamps, so no need to fill up coolingwater). Al in all very easy and max. 1 hour of work. |
ItsGary1457.50 phichi110611.50 |
01-18-2020, 05:15 AM | #4 | |
Rep 7,140
The Rest button enabled the pump with ignition off, but in our case one have to have it on anyways correct? The pump is a good $300 over here so starting to wonder whether I actually want to replace it as I don't see the point with it... You? |
01-30-2020, 06:10 PM | #5 | |
1458
Rep 2,336
'09 ///M3 Sedan - Jerez Black/Fox Red Ext.
'09 335i Coupe - Alpine White/Black - SOLD |
01-31-2020, 02:31 AM | #6 | |
Rep 7,140
Another "use case" - even without the Rest function - could be during stop/start, maybe. Coded this our long ago so in my case do diff. Thanks again though. My fan rarely stays on after turn off (Nordic climat, rarely over 25C Summer...), but will definitely keep this in mind as possible reason to get a new pump. Cheers, Nik |
ItsGary1457.50 |
02-25-2020, 08:21 AM | #7 |
Rep 7,140
Another funny input on this strange pump of mine; had a chat with the dealer thinking of order one still. They checked my vin and said my car should not have one installed. But it has... Ah well, maybe I'll replace it one of these days.
ItsGary1457.50 |
