BMW M3 Forum (E90 E92)
BPM
      04-02-2020, 08:25 AM   #1
drivetolive
89
Drives: Z4M Coupe
Rear Bench Install
I had to remove the entire rear seating in my E90 and no cannot for the life of me reinstall the rear bench .
Everything else went back in smoothly and now it is just the bench left. I understand it is basically two clips, however they do not seem to lock into place when I push down on the seat? I've removed these before on other BMWs and reinstall was as straight forward as pushing down.
I don't see any damage to the clips, but perhaps something is damaged or I am doing something wrong. Any suggestions?
      04-02-2020, 09:27 AM   #2
m3_tristan
Be Original.
m3_tristan's Avatar
267
Drives: 2011 E90 M3
Just push really hard down on the two clips. It should clip in
      04-04-2020, 10:25 AM   #3
drivetolive
89
Drives: Z4M Coupe
Lol I have even tried using my body weight and still no luck. I can feel the clips trying to engage, but just not budging. To confirm, there are only the two, correct?
      04-04-2020, 11:27 AM   #4
rhyary
rhyary's Avatar
Drives: 2013 M3
You need to line up the clip in a way that pushing it will make it go into its place. It is not just pushing harder.
Use a bit of soap or wd-40 type lubricant
      04-06-2020, 05:02 PM   #5
drivetolive
89
Drives: Z4M Coupe
I'll try some soap, thanks for the suggestion.
There isn't anything aside from the 3 seat buckles I need to worry about impeding fitment, correct?
m3post
