BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Coding / ConnectedDrive / Audio-Video / Electronics / Bluetooth / I-Drive & Nav
BPM
      01-23-2023, 05:24 PM   #1
RocketyMan
RocketyMan's Avatar
Drives: E53 X5, E83 X3, E93 M3
2008 BMW M3 E93  [10.00]
Trying to update Combox to UPD01008
I successfully retrofitted a COMBOX and CIC to my M3--and I'm super stoked about this. The BT A2DP function works and sounds good.
When reviewing any potential SW updates, I see that the Combox does indeed have one available. This is my current one when viewing in the CIC SW support screen:
Multimedia MX-003.004.031
Telephone TX-003.004.031
This is my issue, I've downloaded the latest SW to a FAT32 flash drive, and I cannot get it to flash. I know the USB stick in the armrest is getting power because I have a blinky light on it and also verified the black FAKRA is connected to the module. Doing a bunch of research of this has pretty much led me to a dead-end. Certainly I'm convinced it's a coding parameter or something. Also, I verified I have the appropriate $6FL in the FA. NCSEXPERT shows the USB coding aktiv and Here's some of the links I've been trying to follow.
https://www.m3post.com/forums/showthread.php?t=1064602
https://www.e90post.com/forums/showthread.php?t=1061869
Any ideas?
P.S. (also tried a different USB stick--no success)
CIC is a CIC.C1A version
Combox is a CMEDIAR.C05 version
SWUP_ENABLE_SW_UPDATES
aktiv
SWUP_ENABLE_ENG_UPDATES
aktiv
SWUP_SOURCE_USBMSCDD
aktiv
USB_HUB_M
aktiv
2008 BMW M3 E93 MT
R135
..246
      01-23-2023, 05:33 PM   #2
RocketyMan
RocketyMan's Avatar
Current Combox SW
Here is the current SW on the Combox. One thing I think is very interesting is the text is all "greyed out" for the version and such.
Could that point towards the issue?
2008 BMW M3 E93 MT
R135
..246
      01-23-2023, 11:56 PM   #3
Adam M
80
Drives: BMW e92 M3
I did this last week sans was only successful using a tiny capacity usb stick (512 mb).
I had read someone else trying and failing even with a 10gb so found the smallest I could.
I made sure it was visible when looking in external drives and then used the option under the settings menu for software updates.
Make sure the file is in the root directory of the stick.
      01-24-2023, 10:27 AM   #4
RocketyMan
RocketyMan's Avatar
Thanks for giving feedback. I too, tried with a 512MB USB stick and still didn't work.
And yeah, I made sure to have the .bin file as the only thing on the root directory.
When you say that you "made sure it was visible," do you mean in the CIC menu where it lists things like BT, AUX, and the flash drive? This might be a good thing for me to verify as I don't recall if it actually "saw" the USB stick or not. Hmmm.
I'll try again later tonight and see what I see....
2008 BMW M3 E93 MT
R135
..246
      01-25-2023, 12:40 AM   #5
Adam M
80
Drives: BMW e92 M3
Yes I do,
Did you remember to format the new stick to Fat32 first? Ntfs or exfat don’t work.
SaNGRia996.50
      01-25-2023, 01:44 PM   #6
derbo
Derbo Tuning
derbo's Avatar
3613
Drives: BMW M3
Make sure the USB drive is also in MBR format not GPT. That might help too.
IG:ruhrohz_m3
Journal: Link
E9x ZCP Suspension Info: Link
Track Chat Discord: https://discord.gg/VsKbTyqBVj
SF Bay Area: DM For coding services
      01-25-2023, 03:30 PM   #7
RocketyMan
RocketyMan's Avatar
3rd time is the charm!
So I tried with a 3rd USB stick this time and it worked! It was a 2 GB stick. This one was also in FAT32 but it could've also been in MBR in addition. At any rate, it worked!
Thank you guys for the responses!
2008 BMW M3 E93 MT
R135
..246
      04-02-2023, 12:51 PM   #8
Heiko_84
Drives: e93 M3
How can I get the firmware?
      02-09-2024, 06:48 AM   #9
Wifi
Drives: 2010 E90
Heiko_84
After lot of searching on the internet I found version 1006 and 1008.
Sent me a PM and I'll be happy to send you the files, it won't let me attach them here.
Version 1006 I was able to install successfully with a USB flash drive.
For version 1008 I haven't been able to get it to update, it says something like 'Update on USB is not the latest version'.
Anyone knows how to go around this 'problem'?
      02-12-2024, 12:09 AM   #10
emanmor345
Drives: 2011 335d
Originally Posted by Wifi View Post
Heiko_84
could you link me update 1006? Before I go buy a flash drive, "I tried like 5 that i have" update 1008 keeps saying the same as you that the update on the usb is not the latest.
Thanks!
07' E90 N51 Retrofitted : $3AG, $313, $319, $322, $415, $430, $459, $464, $465, $494, $5AC, $524, $541, $609, $6VC
NBT EVO ID4 + ATM W/ carsystems adapter
LCD3, M3 DCT wheel, OSRAM CBB, LUX V8.1
      02-14-2024, 09:22 AM   #11
thecarfixer
Drives: E90 330i
I've been trying to update my retrofitted combox with exactly the same software as the OP, with the same error. Does anyone have the UPD01006.bin file, could they share it?
Thanks!
      02-14-2024, 10:34 AM   #12
Wifi
Drives: 2010 E90
Hi guys, emanmor345 thecarfixer
I couldn't upload the file itself here, but here's the link to download.
This is version 1006, hope this helps.
Also has anyone been able to flash version 1008? It keeps saying that it's not the newest version.
Download link v. 1006:
https://www.dropbox.com/scl/fi/mihn0...k86xcebfp&dl=0
      02-14-2024, 10:43 AM   #13
thecarfixer
Drives: E90 330i
Thanks! I'll try that update now..
I've not been able to get 1008 to work, same error.
      02-14-2024, 11:05 AM   #14
thecarfixer
Drives: E90 330i
OK, so 1006 worked straight away. Will try 1008 again!
[edit] 1008 doesn't work, still, says the version on the USB is older.
      02-14-2024, 11:16 AM   #15
Wifi
Drives: 2010 E90
Yes, it was the same for me.
I'll try 1008 later with a different USB, trying to find one not bigger than 2GB.
      02-14-2024, 03:10 PM   #16
thecarfixer
Drives: E90 330i
I tried it on a few different USB sticks (changed partition sizes to 2Gb), FAT, or FAT32 and same error.
It’s interesting because the OP got it to work..
      02-17-2024, 04:25 AM   #17
DavesZed
DavesZed's Avatar
156
Drives: BMW E89 23i, 2011
Just in case you want to try a different file, here is 1008 on my Dropbox...
https://www.dropbox.com/scl/fo/3deo1...lr4771xx4&dl=0
Dave
2011, E89 23i, Grey with Red leather.... relatively basic (getting less and less basic with every new retrofit)!
My Z4 E89 YouTube channel...
https://www.youtube.com/channel/UCtt...0vHFUQnoEvKB2Q
      02-17-2024, 01:05 PM   #18
RocketyMan
RocketyMan's Avatar
Make sure nothing else is on the flash drive and that you have the .bin on the root directory. Probably the real issue here is making sure the flash drive is in MBR and not GPT.
2008 BMW M3 E93 MT
R135
..246
      02-19-2024, 09:13 AM   #19
thecarfixer
Drives: E90 330i
Same USB for 1006 was used...
[edit] Infact, I converted the USB stick I used to MBR to test, same error, update on USB is older than on the system.
      02-19-2024, 11:08 AM   #20
brettcp
Drives: 2012 E93 M3
Is it possible that the CIC is not on version CIC.C1A, and therefore can't accept 1008? Just a thought. I believe you need an ICOM to update the CIC properly if I recall.
      02-19-2024, 11:18 AM   #21
thecarfixer
Drives: E90 330i
I've updated it myself to C1A, I used the patcher to install FSCs that won't work without this code index.
      02-20-2024, 01:20 AM   #22
DavesZed
DavesZed's Avatar
156
It makes no difference of the firmware level of the CIC for this update. I did mine, with the file I've linked above, quite a while before I had the CIC updated
Dave
m3post
