11-22-2023, 01:19 PM | #1 |
1558
Rep 2,084
cooling ducts / backing plates
picked up a GT4 lip that I'd like to get installed this winter, but wasn't sure if there was a consensus vendor for backing plates and the ducting itself. what have people been using? i found these guys, but i assume there's something stateside too:
https://www.mk-motorsportteile.de/en...-plates-1m-gt4
Current '21 DG X5MC, '22 X5M50i, '11 E90 M3
Recent Past '12 E92 M3 ZCP, '08 E93 M3, '18 F80 ZCP, '04 E46 M3 I think I have an M3 problem. |
11-22-2023, 05:50 PM | #2 |
Rep 4,183
11-22-2023, 10:55 PM | #3 |
Dont listen to me
810
Rep 579
i just installed Burkhart Engineering carbon brake cooling plates and 63 mm hoses to a gt4 lip. Went together very well. The hole in the carbon cooling plate is centered half way between the rotor center hat and inner rotor face, but seems like air would want to move back toward the center hat when the car is at speed.
Does it work? I have no idea yet, but we will find out Dec 1 at Road Atlanta.
Instagram: @thatwhitem4
tsk941526.00 |
11-24-2023, 01:59 PM | #4 | |
1558
Rep 2,084
11-24-2023, 02:32 PM | #5 |
Rep 1,504
I’ve been running the Hard
Motorsports brackets which direct air to the inside of the rotor ring, which it needs to be for maximum effect. Perfect fitment and no issues.
2011.5 E90 M3 DCT ZCP Slicktop
tsk941526.00 |
11-24-2023, 02:40 PM | #6 |
1558
Rep 2,084
boo. on sale but sold out.
12-28-2023, 08:38 AM | #8 | |
1558
Rep 2,084
short of re-bending that standoff to be shorter I'm not sure these are usable..
12-30-2023, 02:55 PM | #9 | |
Rep 5,937
01-04-2024, 08:32 AM | #11 |
Dont listen to me
810
Rep 579
yes, its the OG Shark version and am running 120 N/mm front and 180 N/mm rear (685/1028 lbs/in) springs.
01-04-2024, 08:41 AM | #12 |
Rep 5,937
Nice. 685/1028 lbf/in rates should work well. 700/1000 lbf/in is a common setup on MCS dampers. MCS 2WR dampers are still decent on the street at those rates but you can reduce C damping which really makes things civilized.
01-04-2024, 09:42 AM | #13 |
Rep 1,597
I ordered the AliExpress ones. They showed up quickly, were cheap and the quality is surprisingly very good, especially for the money.
The inlet is quite small (haven't measured it yet), so I'll need to source some smaller tubing, but I think they'll work well... |
01-04-2024, 10:56 AM | #14 |
1558
Rep 2,084
can you do a test fit? mine didn't line up at all, and wouldn't clear the rotor with the standoff the way it is.
01-04-2024, 03:25 PM | #15 | |
Rep 1,597
I can't test fit them on the car - it's currently away in storage. I do have a set of Storm uprights though that I can see if the holes up line at all. But in terms of rotor clearance, I won't know until the spring when everything gets installed. |
01-04-2024, 03:45 PM | #16 | |
1558
Rep 2,084
01-04-2024, 03:52 PM | #17 | |
Rep 1,597
01-04-2024, 04:01 PM | #18 | |
1558
Rep 2,084
also the video isn't for the ali kit, it's for whoever they knocked off (unless I misunderstood it)
tsk941526.00 |
01-04-2024, 04:14 PM | #19 |
Rep 1,597
01-07-2024, 02:00 AM | #20 |
Rep 9,034
Good thread. Has anyone run the Porsche GT3 air deflectors on the suspension arms?
01-07-2024, 03:21 AM | #21 | |
Rep 4,183
https://www.m3post.com/forums/showthread.php?t=1406400 |
02-18-2024, 02:29 PM | #22 |
Rep 1,597
Follow-up... The Aliexpress specials DO NOT fit. I tested them on my storm uprights I have sitting waiting to be installed, and they are not even close to lining up properly.
