04-01-2008, 11:42 AM | #1 |
Rep 536
Let's Euro Headlight Switch the 1 Series (enable Rear Foglights)
135i cars in Europe come equipped with Rear Foglights. I assume BMW NA thinks American’s don’t know the proper time to use Rear Foglights so this feature is not on the US spec cars. Since the Rear Foglights work off of the Adaptive Brake Lights, the bulbs are already in place. In order to activate the Rear Foglights on the 135i, you need to replace the headlight switch with the European version.
Installation Installation requires a T-20 Torx driver. To begin installation, locate and remove the 2 T-20 Torx screws at the bottom of the headlight switch panel. Remove the driver side vent cover by pulling up. Once the vent cover is removed, you will find 2 more T-20 Torx screws. Remove them. With the screws removed, you can lower the panel. Pull the leading edge of the side panel away from the dash. There are 2 clips that will free themselves. You do not need to remove the panel entirely, just enough to un-dock these clips. The Headlight Switch panel will lower down. You only need to lower it, you do not need to remove it. With the screws removed, you can lower the panel. Pull the leading edge of the side panel away from the dash. There are 2 clips that will free themselves. You do not need to remove the panel entirely, just enough to un-dock these clips. With the panel lowered enough to see the back of the switch, you will see the electrical connector. The connector has a gray lock that when you move it toward the passenger side of the car, will unlock the connector. Unlock the connector and disconnect the wiring harness. With the harness unconnected, you can remove the switch from the panel. There are 4 clips that hold the switch in place. You will need to press in the clips and remove the switch. With the switch removed, install the new switch into the panel. Make sure all 4 clips fully dock. Listen for the clip sounds and push on the switch from the front to make sure they are docked. With the switch installed, reconnect the wiring harness and lock it in place. Raise the front of the panel up and install the 2 T-20 screws at the base of the vent. Install the side panel making sure the 2 clips engage. Re-install the vent trim panel and re-install the 2 T-20 screws at the bottom of the headlight trim panel. You are done. when the Rear Foglights are active, you will get a rear foglight indicator in the instrument cluster. Tail lights on Rear Foglights on Last edited by AndyM; 06-23-2016 at 02:39 PM.. |
04-01-2008, 12:01 PM | #2 |
Rep 7,594
Drives: '19 M2C
You are the man!
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange) |
04-01-2008, 01:46 PM | #5 |
Rep 134
Aren't those the lights that are suppose to come on during emergency braking ala the 2 stage brake indicators.
[SIGPIC][/SIGPIC]
2008 BMW 135i Coupe *Blue Water Met *Black Leatherette *Glacier Alum *Sports Package *Comfort Access *Heated Seats *Ipod/USB adaptor |
04-01-2008, 02:28 PM | #6 |
Rep 536
04-02-2008, 06:30 AM | #8 |
Rep 905
Call me the dumb American, but when would you need to use them?:iono:
2018 BMW M3 - 12.1 @ 121mph
2014 BMW 335i M-Sport (Sold) 12.4 @ 113mph 2008 BMW 135i (Sold) 12.8 @ 106mph |
04-02-2008, 07:04 AM | #9 | |
Rep 1,340
Drives: 2008 135i SGM MT
Garage List 1995 Acura Integra SE [0.00]
2008 BMW 135i [0.00] 2006 Porsche Cayman S [0.00] 1999 Toyota 4-Runner [0.00] |
AND...........Thanks, Andy.........I just ordered one :biggrin: Looks nice and a good safety feature.
2008 135i SGM |
04-02-2008, 07:11 AM | #10 |
Rep 536
Exactly. When I was driving my car home through the Smokies we had very dense fog on Saturday morning. You could see maybe 15 feet in front of the car and the only time you saw cars ahead was when they were on the brakes.
04-02-2008, 07:30 AM | #11 |
Rep 905
That's what I thought was the reason...just wanted to clarify. Seems like a good safety device...when used properly of course.
04-02-2008, 07:50 AM | #12 |
Rep 295
I will definitely do this with the 135. I activated the rear fogs on my MINI when BMW would not (they eventually offered it as an official option) and the switch was $90 at teh cheapest and you had to have the dealer program them to turn them on, which they usually charged for, so it is nice to be cheaper on the 1.
04-02-2008, 10:37 AM | #13 | |
Rep 536
04-02-2008, 11:38 AM | #14 | |
Rep 536
04-03-2008, 01:27 PM | #16 |
NRA Life Member, BMW CCA 30 year member
182
Rep 2,614
Yep, that's a cool mod, be doing that as well.
M3, nice of you to include my car in your sig.:wink:
Resigned 1ADDICTS Moderator
To disarm the people is the best and most effective way to enslave them. George Mason |
04-03-2008, 02:12 PM | #18 |
Michelin Man
445
Rep 755
04-03-2008, 02:34 PM | #19 |
Rep 536
04-03-2008, 02:43 PM | #20 |
Addicted Member
15
Rep 603
Thank you.
[SIGPIC][/SIGPIC]
04-03-2008, 04:38 PM | #22 |
Rep 536
