TireRack
Go Back   XBimmers.com | BMW X6 Forum X5 Forum > BMW X5 Forums > General BMW X5 (E70) and X5M Forum (2006-2013)
      05-07-2024, 09:40 AM   #1
Nic0las456
Drives: BMX X5 xDrive 35i
Cool 28A0 - Re group to fix tihis issue together! BMW X5 xdrive35i
Hello Guys,
I got this BMW X5 2012 xdriv35i E70 last year and I am trying to keep it for long term.
I have been dealing with a code : 28A0 ( Air Mss System, plausibility: Calculated air masses in the air intake system not plausible) for long time.
This is was has been done to the car related or not to the issue:
Order:
RELATED:
DMLT VALVE replaced
Purge valve replaced
charge pipe replaced with FTP
Valve cover and other parts replaced. OEM
TMAP/MAP Sensor replaced (intake and charge pipe)
MAF sensor cleaned and new gasket installed
Superjet pump vacuum hose replaced
Air filter box gasket replaced.
NOT RELATED:
Current Miles: 110.000
Oil filter and gaskets MANN, Oil 5w30 Liquid Moly , air filter MANN , drain plug and gasket - changed every 5k miles.
PREMIUM 93-94 octane fuel (Delta, Shell, Sunoco)
Brakes pads , rotors and sensor
Parking brake actuator
Spark Plugs and Coils
Oil filter housing gasket and mickey mouse replaced, coolant flush
Transfer case fluid changed
Differentials fluid changed.
Transmission fluid and filter changed.
Heater control valve
radiator cap
steering wheel cap
L/R Mirror glasses
Right interior temperature sensor HVAC
AUC Sensor
Exterior and Interior HVAC Filters
Parts supplier: FCP EURO (OE/OEM)
I have been doing some smoke tests and this is what I found and Fixed.
Charge pipe leaking: FIXED
Maf sensor leaking: FIXED
Map Sensor leaking: FIXED
Superjet pump vacuum line leaking: FIXED
Air box filter gasket leaking: FIXED
Valve cover gasket leaking: FIXED
besides that I can't find more vacuum leaks with my smoke teste, I don't see any smoke coming out anywhere.
What else can I do ?
Something also weird is that the EVAP Monitor never gets done.
Car runs perfect , no issues , no bad idle, not knocking (just some times you can feel a small misfire but the RPM does not go crazy.
The light and code triggers when the car is being drive at constantly low RPM (1000rpm-1500rpm) and around speed of 25-35mph.
If avoid those situation I won't get the light but I will get the code sometimes as pending.
I am tired of this code
Some Live data:
Short trim fuel are usually at 0%
Long term fuel are usually at -2,3%
Short trim sensor 2 is usually at 99.2%
O2 b1s1 is usually at : 1.4 - 1.5
O2 b1s2 is usually at : 0.7
Intake manifold pressure after throttle valve: 13.93 psi
Intake pipe vacuum before throttle valve (charging pressure - setpoint value) : 14.65 psi
Intake pipe vacuum before throttle valve: 14.63 psi
Charge air temperature: 115.7 F
Please let me know what else can I do to diagnostic and fix this code, It is the only code that the car has.
Thank you so much!
      05-07-2024, 03:24 PM   #2
Spaceme1117
89
Drives: 2013 BMW 335i xDrive
To me this sounds like you may also have a leak somewhere in the EVAP system coming from the fuel tank. The EVAP system can cause a vacuum leak as it is also plumbed into the intake.
Can you smoke test that?
Other possibility is this from a couple of threads on BimmerFest forum:
https://www.bimmerfest.com/threads/2...essure.977220/
The last post says this "Remove tank valve connector which is right beneath the airbox, let the car idle for 15min and plug tank valve connector back in. Clear the codes and it should remove the code permanently, works 95% of the time."
This post shows what connector that is: https://www.bimmerfest.com/threads/n...stion.1026257/
This thread suggests that this is a procedure to reset the adaptation for this system. Seems worth a try and may fix your code.
xbimmers
