01-14-2009, 10:47 PM | #1 |
Rep 4,038
-=EMS=- BMS Products JB 1,2,3 / Intakes/ Cdv Mod
JB3 Ver 1.22 READY TO SHIP!
JB Stage 1 $ 99 A lower boost version of the JB, offering 20-30 rear wheel horsepower and 30-40 rear wheel torque gains. Installation is slightly easier than the Stage 2, and peak boost is limited to 9.75 psi. Does not require solenoid bypass. This is how the car should have come from the factory! JB Stage 2 $ 229 Our most popular tune, offering 40+ rear wheel horsepower and 50+ rear wheel torque gains on 91 octane, or 50+ rear wheel horsepower 60+ rear wheel torque gains on 93 octane when coupled with the hot pill. Peak boost is set at 11psi and tapers at high RPM for long compressor life, and air/fuel ratios are remapped for maximum performance. JB Stage 3 - Professional / pin out harness $ 379 The latest generation of the Juice Box Performance Tuner features completely new microcontroller based hardware, numerous additional input/output channels, safety features, a plug and play wiring harness, and gains of up to 80 horsepower and 80 torque to the wheels on an otherwise stock car! Compatible with 29.2/v81 ECU. *The pin-out (suggested for more experienced enthusiasts) uses OEM BMW pins in similar manner to JB1 and JB2, and has an install time of 30-45 minutes. Neither version requires the solenoid bypass or any vacuum line changes making removal a snap! JB Stage 3 - Plug and play harness $ 629 The latest generation of the Juice Box Performance Tuner features completely new microcontroller based hardware, numerous additional input/output channels, safety features, a plug and play wiring harness, and gains of up to 80 horsepower and 80 torque to the wheels on an otherwise stock car! Compatible with 29.2/v81 ECU. BMS single intake $ 129 Offering 8-15 rear wheel horsepower gains, the BMS intake replaces your restrictive factory airbox assembly with a custom built K&N brand filter. Features ~20% more filter surface area and much better sound than the factory airbox, all without raising your intake air temperatures. Fits BMW 135 / 335 / 535. BMS dual cone intake $ 139 Prefer the look of a dual cone? Featuring quality S&B inverted cone filters our dual cone intake offers the highest possible flow in an attractive and easy to install package. Includes anodized black aluminum couplers and all required hardware. Fits BMW 135 / 335 / 535. BMS modified Clutch Delay Valve $ 20 A must have for any stick shift, the BMS clutch valve replaces your factory clutch delay valve with a professionally ported valve. The result is quicker shifts, longer clutch life, and improved 0-60 times. Installs quickly and is visually identical to the factory valve. Fits BMW 128 / 135 / 328 / 335 equipped with manual transmission. *not including shipping Check out the site to order and more details http://www.exquisitemotorsports.com/...lts.asp?Cat=63 |
