04-27-2009, 04:21 PM | #1 |
Sleepy Member, wishing I was on the road.
34
Rep 280
Low Profile Floor Jack
Hey guys,
I've decided to just go ahead and buy a low profile jack rather than fiddle with ramp extensions and what not. I can't seem to locate the required clearance. Anyone know exactly how "low" a low profile jack I need? Thanks
2003 Ducati '996
2008 M3: Sparking Graphite, Red Fox Standard, 19s, Premium pkg, Tech pkg, Premium Enhanced Sound, HD Radio, Heated Front Seats. |
04-27-2009, 05:45 PM | #2 |
The Jesal
391
Rep 5,859
I have this one. http://www.harborfreight.com/cpi/cta...emnumber=40105
It fit under my lowered NSX so im sure it will work with a lowered M3.
2009 E90 M3 - SOLD
04-27-2009, 05:49 PM | #3 |
34
Rep 280
Did your NSX have a center jack point that you could reach with this jack, or did you just grab the side rails?
2003 Ducati '996
04-27-2009, 06:03 PM | #4 |
The Jesal
391
Rep 5,859
Well the NSX had a center side rail point so i used that mostly.
Where you thinking about jacking the car up from?
2009 E90 M3 - SOLD
04-27-2009, 06:15 PM | #5 |
34
Rep 280
The center jacking point near the front wheels...
This is of the E46, but I know that the center puck is there for the E92 but i had to drive up several planks of wood to get a jack underneath the body. http://www.m3post.com/forums/showthr...jacking+points
2003 Ducati '996
04-28-2009, 10:55 AM | #6 |
34
Rep 280
http://www.1addicts.com/forums/showp...2&postcount=47
found a picture of this jack on the 1series site. I think this is a viable solution. Anyone else have this jack or know where to get it?
2003 Ducati '996
04-28-2009, 11:07 AM | #7 |
34
Rep 280
http://forums.corvetteforum.com/c6-c...c-dk13hlq.html
i guess now its just a matter of going out to the car with a measuring tape.
2003 Ducati '996
04-28-2009, 12:55 PM | #8 |
Rep 610
I bought mine at costco. I believe if itt can clear 5" then you are fine. I measured my car and i believe its 5"
EDC.....viagra for your car
05-05-2009, 12:36 PM | #9 |
34
Rep 280
36" to the center jack point... i know of no jacks with this reach...
2003 Ducati '996
05-05-2009, 01:02 PM | #10 | |
Bates '08 Interlagos Launch
126
Rep 1,230
This Harbor Freight jack is GREAT. It strong, lightweight, has a quick release arm, jacks up quick, and its inexpensive! I've used mine for 4 years at racing events for my z06. Lots of guys at the track use them. |
05-07-2009, 03:32 PM | #11 |
Rep 660
i got mine from costco.. it's light and to the max height, it only requires 5 pumps
Future mod consideration: exhaust, pulley
otherwise, very happy with how the m3 was born |
05-09-2009, 10:33 AM | #12 |
Lateral G
33
Rep 128
I bought this jack last weekend from Harbor Freight. First time I used it on the central jacking point I heard a "pop" and then all the hydraulic fluid spilled out on my garage floor. Took it back the next day for a refund. Maybe I got a defective one?
05-14-2009, 01:12 AM | #14 | |
Rep 6,107
Get a Torin Aluminum Jack & Stands from Northern Tool ... it is on sale now ! |
05-14-2009, 01:13 AM | #15 | |
Rep 6,107
05-15-2009, 12:02 AM | #16 |
Rep 961
I just bought one of these lifts. I should have it around the end of June or so. I got it through a group-buy at www.gotogroupbuy.com.
http://www.ezcarlift.com/ I'm thinking it will be less hassle and faster than the two-garage-jacks method I use now for getting the car in the air. |
05-26-2009, 09:09 PM | #17 |
Rep 5,012
I just splurged with a 2-ton Craftsman aluminum 'racing' jack. It was on sale from $220 to $180. It's only 3-2/3" fully lowered, and raises to 19" (specs have different numbers, but I measured them). And it weighs nothing compared to my old jack. It should serve me well until I'm too freaking old to do my own maintenance . Oh, and it looks 'kewl' .
06-09-2009, 12:45 AM | #18 |
183
Rep 2,872
I suggest not using the 2-3 ton craftsmen low profile jack
It is way too thin walled and not a wide enough base. The LED base model to be precise We were using one last weekend at a track event on an E46 and the damn thing folded and warped into pieces shattering into itself. The E46 M3 is a little lighter so put that in perspective. Not good to skimp on a good low profile jack, lesson learned |
