05-08-2009, 11:38 PM | #1 |
Rep 12
Shift Light for 6MT?
Has anyone installed a shift light on a six speed E9x M3? (Let's not discuss why BMW chose to omit this.) I would really like to install one.
05-09-2009, 06:21 AM | #2 |
///M-Flight VP
77
Rep 669
Drives: '13 Frozen Red Edition E92 M3
I have shift lights on my BMW Performance Steering wheel...
2013 "Frozen Red Edition" E92 M3, M-DCT with all the 'fixin's, Akrapovic Evolution w/CF Tips, BPM Stage 2 Tune, BPM DCT Software
05-09-2009, 09:00 AM | #3 |
29
Rep 35
Hello, M3 Fighter Pilots!!
My M3 friend (6MT) has succeeded to install Shift Indicator, using the information of my site. In Japan, some products are sold as follows. This is DIGITAL type, like BMW Performance Steering LED. This is ANALOG type. These Shift Indicator is made by Pivot, and model list is here. The Tacho Signal (Engine Spark Pulse Signal) can get form OBD-II Port. Pin 9 is "Tacho Signal" and pin 4 or pin 5 is "Earth" (Signal Ground). Some information about "Tacho Signal" (OBD-II Port) see here. (Sorry, This site is written in Japanese.)
05-09-2009, 11:09 PM | #4 |
Rep 12
Thanks for the information, I will look for this connector. I'm an Electrical Engineer so I will check out the signal with an oscilloscope.
This is very helpful! |
05-16-2009, 09:11 AM | #7 |
Rep 5,069
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
Garage List 2009 Porsche 911 997.2 [10.00]
2019 Hyundai N (Sold) [10.00] 2013 BMW M3 (Sold) [10.00] 2011 1M Coupe (Sold) [8.78] 2008 E90 M3 (Sold) [8.60] 2007 Z4 Mcpe (Sold) [9.50] 2005 BMW M3 (Sold) [10.00] |
I think if someone really wants shift lights, the Performance SW is the way to go! Plus you get the other functionallity that comes with it.
05-18-2009, 08:53 AM | #8 |
Rep 12
I was just about to by a light when I read the above. When you get performance SW what is used as the light? What software would you recommend?
05-18-2009, 09:13 AM | #9 |
Rep 5,483
Really? Some of you guys think this is necessary in a 6MT? I don't see why you would need it, and especially not the ones posted above. They belong in Hondas/Toyotas.
If you really want one, then throw the money down for a Performance SW
Current:
2019 BMW X5 40i - Carbon Black/Tartufo Individual Leather 2020 Range Rover HSE - Black/Black 2020 Audi R8 V10 Performance Spyder 6MT - Ascari Blue/Black |
05-18-2009, 10:09 AM | #10 |
Rep 8,033
To avoid catching the limiter on the track...I'd rather not spend $1k on a new steering wheel I don't need if I can find an alternative solution for much less.
05-18-2009, 10:35 AM | #11 | |
Rep 5,069
http://www.m3post.com/forums/showthread.php?t=163635
05-19-2009, 08:08 AM | #12 | |
Rep 12
I have found two shift lights that look like winners and have made some paper tube models to try and figure out where to mount them. Right now I am leaning toward an A-pillar mount. But there are options within the tech screen recess, on top of the dash between the humps and also within the instrument cluster on the right side. I am also considering a single super bright LED mounted so it's completely out of sight when unlit. The solutions cost between $100-$150 and should be able to be installed in a couple of hours. It'll probably still take me some time to get around to it, but I'll post my install once I have it done. Here are the shift lights I have been looking at: http://www.raptorperformance.com/pro...hift_light.htm http://www.speedhut.com/product_deta...NUMBER-737.htm Or this one with an external lamp for a more stealthy install: http://www.raptorperformance.com/pro...RPM_Switch.htm |
05-19-2009, 09:05 AM | #13 | |
Rep 8,033
I would like to have the light right above the dash so that I don't have to look down or to the side. But if it is bright enough, it might not matter all that much as it would get your attention. Please let us know how you end up setting this up. If you post a DIY for the wiring, that would be great; I'll add it to the DIY index.
02-11-2012, 06:11 PM | #14 |
Factory Pilot
Rep 60
Drives: E92 Jerez Blk ZCP 6MT
Shift lights, REALLY? Why buy a MT? IMO I'd spend the $$$ on another mod.
11-29-2012, 07:13 PM | #15 |
Rep 1
M Performance Steering Wheel
This thread may have already answered your steering question, but I'm jazzed that this ties in perfectly with something I was listening to yesterday
http://stitcher.com/s?ABoAAKnyu=refid&twsn Embedded in the steering wheel is a display embedded that features Gforces, with shift lights, an accelerometer, & a 1/4 mile mode, with red, yellow & green start. The audio specifically about the wheel is in the final 5 minutes of the clip linked above. |
11-29-2012, 08:16 PM | #16 |
3387
Rep 7,541
I tried for a week getting the DCT shift lights to work in a 6MT and I'm sorry to say that it seems impossible using the factory modules... I believe the DCT control unit is what sends the command to the cluster to make the lights go on, so without the DCT control unit in there there is nothing telling them to turn on ;(
I was really disappointed by this, but am going to look into adding a module which will make the shift lights work in manual cars.
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |----- ----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133---- |
11-29-2012, 08:36 PM | #17 | |
Rep 557
Good man, make it happen. I'll buy the first one.
11-29-2012, 09:24 PM | #18 | |
27
Rep 113
That will be great! I will get one also.Keep it up! |
11-30-2012, 01:29 AM | #19 | |
IG: limited.slip
331
Rep 1,918
And if you need a light to tell you when to shift at an hpde that's kinda sad :X |
11-30-2012, 02:06 AM | #21 |
Rep 5,506
11-30-2012, 11:32 AM | #22 |
Rep 3,387
shift light |
