BMW M3 Forum (E90 E92)
EXXEL Distributions
      06-20-2009, 12:24 AM   #1
leJUNd
leJUNd's Avatar
89
Drives: e90 M3
spacer removal?
Any tips on removing the spacers? It's really on there and it won't budge.
      06-20-2009, 12:32 AM   #2
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Did you happen to use any anti-seize?
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22
GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM
      06-20-2009, 12:34 AM   #3
leJUNd
leJUNd's Avatar
89
Drives: e90 M3
no... I just slapped the spacers on there.
Wish I had seen your thread.
      06-20-2009, 12:41 AM   #4
tom @ eas
tom @ eas's Avatar
Drives: BMW
2018 BMW i3s  [0.00]
2010 BMW M3  [6.50]
2015 BMW M4  [5.25]
Working the spacer off evenly with a pry tool should get it off, just take your tine so the spacer and/or hub is not damaged.
      08-25-2009, 09:50 PM   #5
Silver Standard II
John 3:16
Silver Standard II's Avatar
Drives: 10 550i & 08 M3 VERT
A suggestion...hire someone.
-John
iND Portfolio Project
ESS VT1-535,20"BBS.LM,Nitto.Invo,ColorMatched Brembos,H&R's,Vorsteiner.Lip(iND.Molded),Challenge .Rear(iND.Molded),OEM.Perf.Shift,
LeatherZ.Alcantara Shift & E-Boot,Eisenmann SP w/Fabspeed.X-Pipe-Thank You iND!
      08-26-2009, 04:31 PM   #6
808MGuy
808MGuy's Avatar
219
Drives: 2009 E90 M3
Just give it a good whack with a rubber mallet. Should fall right off. I had to do the same with my Audi when the wheels would seize to the hubs. I got it down to a science where one strategically placed whack would dislodge the wheel. Then once you get it off, apply anti-seize for next time
2016 Porsche Cayman GTS - Sapphire Blue / Black Full Leather Interior / Carrera S Wheels
      09-19-2009, 10:34 PM   #7
V1.47fan
Drives: TheArtist formerly known as M3
Using this method,it's very easy.
Get a torch,they run about $20 and a long flat (very thin) chisel from ACE,HOME DEPOT etc.
First heat the spacer for about 45 seconds with the torch making it hot then use the chisel to pry the spacer from the hub at the 12 o'clock position then 3 0'clock position and so on... down around
Each side took me less than 10 minutes.
m3post
