07-26-2009, 10:31 AM | #1 |
Rep 3,888
Noelle Motors 4.6l conversion
Well, its nothing new, but plus to Dinan an RDsport, Noelle Motors also has an increased capacity upgrade for the S65 engine: 4.6l V8, 520 hp@8.3K and 500 Nm@4.2K . Its a good thing for those that are in Europe.
http://www.noellemotors.de/4_6l_engi...ee94848.0.html There is also a stroker kit for the S85 engine: 5.8l V10 630 hp, 630 Nm. If not, I do not know if its the right place to ask my question, but does a stroker kit affect the perfect balance of the M3? Increased capacity should mean more weight, and so more heavy front? |
07-26-2009, 10:57 AM | #2 | |
Automotive Industry Insider
462
Rep 1,948
Aftermarket performance shops with the proper training, tools, and experience to build a stroker engine, typical use lightweight forged steel connecting rods and lightweight forged aluminum pistons. These aftermarket spec'd engine parts are on average lighter than their stock OEM parts they are replacing. It also depends on whether the engine was BORED and STROKED...or just STROKED. (leaving the orignal factory bore sizing intact) In some cases, the OE CRANKSHAFT is replaced...in some cases it is not. If the crankshaft is replaced with an aftermarket one, it is even more important to balance the entire reciprocating mass as a single unit to avoid damaging engine vibrations issues later on. It takes a lot of experience and technical knowledge to properly build a BMW stroker engine. It's certainly not something you'd want your local engine builder (who builds 350 Chevy engines) to try.
The best is yet to come...
07-26-2009, 10:57 AM | #3 | |
Rep 1,164
-Andy
2008 M3 Sedan- Alpine White
07-26-2009, 11:59 AM | #4 |
Rep 3,888
Thanks for the replies. About the quality there is nothing to doubt with Dinan, RDSport or Noelle Motors (former BMW ALPINA engine development responsible) . So if the weight is not an issue, it may be better than a supercharger, for it is more reliable.
07-26-2009, 12:21 PM | #5 |
Rep 5,012
I think that's critical to do on a +15% stroker engine revving to 8K+ rpm, regardless what's replaced, but could be wrong. Great point man.
07-26-2009, 12:21 PM | #6 | |
Rep 1,164
-Andy
07-26-2009, 01:15 PM | #7 | |
462
Rep 1,948
The stock S65 engine uses forged steel/magnesium connecting rods, but the stock pistons are not forged. They are made of CAST aluminum which have a durable iron metal anti-friction coating on the piston skirts. I believe the OE manufacturer of those pistons is MAHLE. The crankshaft is made of high-strength forged steel, not aluminum. The OE BMW Motorsort crankshaft uses counter-balancing weights to reduce engine vibration in the 90 degree S65 V8 engine, so if the aftermarket crank is custom machined without these (or smaller lighter ones)...then you could still end up with a lighter overall crankshaft despite the longer throw. Our OE crankshaft may or may not weigh more depending it's construction. BTW: Aluminum connecting rods (even forged ones) would be far too fragile to handle the stress of 8000+ rpms for a street car. It wouldn't take much time for these to fail under high stress loads. Some engines like the Corvette Z06 use forged titanium connecting rods to reduce overall reciprocating mass in the large 7.0-liter V8 engine. It also uses CAST aluminum pistons by the way...
07-26-2009, 01:34 PM | #8 | |
Rep 5,012
You could get away with that on an I6 engine since it has perfect primary and secondary balance, but a 90º V8 has only perfect primary balance (no need for counterrotating balance shafts), so you need to quell the secondary order vibrations. It'd be nice to hear from the stroker folks to see what they're actually doing in that regard. And from stroker owners to see if they perceive more engine vibration. Doing things right definitely costs a lot of money, so I wouldn't be surprised if you're correct. Good day. |
07-26-2009, 01:56 PM | #9 | |
Rep 1,179
But now things should be much easier for me |
07-27-2009, 08:34 PM | #10 | |
Rep 8,033
07-29-2009, 04:29 AM | #11 |
Rep 3,888
Wow, the RDSport crank looks so much better than the OEM crank. It look lighter and of better quality.
As for the price I do not know, but I do not think it is convenient for those that are not in EU, unless NM has some other places where they can do the work. |
07-29-2009, 06:02 AM | #12 |
Rep 40
Well, Noelle is in Germany and Racing Dynamics are in Italy...
08-14-2009, 01:46 AM | #13 |
9
Rep 62
Noelle = Dinan
I have a feeling, lookinag t bore/stroke ratios and previous conversations i have had with KO Noelle, that him and Dinan are cooperating. He claimed to me that Dinan's original V10 stroker was his development. Did Dinan return the favour on the V8?
Racing Dynamics S.p.A. and RDSport sell the same RS46 product, so if you want worldwide support from 1 company, you have an option. |
08-14-2009, 02:06 AM | #14 | |
462
Rep 1,948
It was made using low-sulphur CORUS EN40B chromium-molybdenum nitrided steel. (hardened and tempered)
08-21-2009, 03:34 PM | #15 |
///M-Flight VP
77
Rep 669
Drives: '13 Frozen Red Edition E92 M3
Hmmm..I think I'm gonna contact these guys for pricing...they're also located in Fussen...if anyone has ever been in that area...its where the Neuschweinstein castle is located...and the roads there are absolutley amazing and scenic!!!!
08-21-2009, 06:33 PM | #16 |
86
Rep 2,148
PencilGeek, that photo explanation just made my jaw drop. Like you said, that crank looks sooO good compared to the OEM S65 crankshaft. Smooth+less turbulance and better flow= One Bad Mama Jama of an Engine!
08-22-2009, 09:29 AM | #17 |
Rep 504
I was not aware that airflow/turbulence were issues with a crankshaft (and I'm a bit skeptical). I figured it was all about balance.
08-23-2009, 04:17 AM | #19 |
Rep 1,895
Price for Stroker
I recv'd an e-mail from Karl-Otto Noelle of Noelle Motors. The stroker costs 22,000 Euro. Take 19% VAT off that it and at the current conversion rate it equates to $26,437. I think I'll pass. I was hoping it'd be around the $8K range. That, I'd do.
He didn't offer up the Tune cost yet. This may be a more affordable option. |
08-24-2009, 12:07 PM | #21 | |
Rep 1,895
Here's a couple more tunes from the Brits complete with exhaust - http://ca-automotive.co.uk/products-...faWQ9OA==.html |
12-07-2010, 02:32 AM | #22 | |
Rep 860
noelle motors, s65, stoker kit |
