05-15-2010, 02:10 AM | #1 |
8312
Rep 18,880
Drives: BMW
▀▄ eas - 2011 LCI Taillight Retrofit Overview - Q&A
The release of the 2011 LCI (Life Cycle Impulse) introduced some minor improvements to the vehicle. On the exterior side, most noticeably with the taillights. This DIY will give a quick overview for those to update their lighting to update the rear of their 07-10 3-series Coupe or Convertible to appear like the 2011 models.
An LCI Upgrade consists of inner/Outer taillamps, trunk lamps (4 total) and Plug and Play (PnP) harnesses. Our example will be performed on a 2010 M3 Convertible, which is the last production year of the Pre-LCI lamps: On pre-LCI vehicles (>2011), there are a series of "checks" that are performed when the ignition is turned on. Once of these processes is called "BulbCheck", which sends small voltage pulses to the various exterior lamps of the vehicle and expects a load on the circuit - which a stock halogen bulb would give. The voltage used is very small, not enough to light up the bulb - so it's never seen. LEDs require very little voltage to operate, and can pick up these pulses - which is the "flickering" seen when the ignition is activated: BulbCheck in action. This also results in errors on the instrument cluster/iDrive screen since the vehicle thinks the bulbs are non-functional. Coding will tell the vehicle (4 different control modules) that LED lamps have been retrofitted and that BulbCheck isn't required in those specific fields any longer, allowing the vehicle to operate like normal. Here's a quick video of the LCI taillamps in action to show the differences before coding and after coding is performed: The LCI Taillamps are 100% functional after installation as seen in the component test, I want to make sure everyone is clear that the vehicle is not unsafe to drive if the end user has not yet had a chance to get the vehicle coded. Do keep in mind that coding is required for a proper installation and targets correcting the bulb-out indicators on the instrument cluster/iDrive as well as pre-ignition flickering upon startup. This will also ensure that no future errors are present if the vehicle should ever visit the dealer for other service updates or maintenance work. The following modules are coded: Car Access System (CAS) Junction Box Electronics (JBE) Footwell Module (FRM) Instrument Cluster BulbCheck is removed for only the lamps that were replaced by LEDs, all other monitoring systems are kept in place. A LOT of work has gone into making sure this was performed correctly - even providing log sessions of 16 different vehicles, including making a trip to the dealership to scan vehicles with pre-equipped LCI builds in log comparisons. Coding will also allow the vehicle to pass all verification and safety checks, as well as not provide any issues if the vehicle is ever brought in for service - since we are using original BMW parts and proper coding has taken place, rather than attempting to "band-aid" the situation with add-on resistors (which are dangerous). Here are some shots of the FRM2/FRM3 location underneath the driver's side footwell: You do not need to upgrade to FRM3 for LCI Coding!For those looking to inspect what type of FRM they have, the part label will have either FRM2 or FRM3 displayed, we have the ability to code either FRM2 or FRM3 modules: Thanks for reading, feel free to respond with any questions - with the intention of keeping this a technical-specific thread.
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by tom @ eas; 11-27-2012 at 07:03 PM.. |
05-15-2010, 02:24 AM | #3 |
8312
Rep 18,880
Drives: BMW
You sir, have one awesome M3. About to get even better from what we talked about today.
05-15-2010, 02:38 AM | #5 |
Rep 598
Where can I get the coding done? Any dealership? Can I bring my car to your shop?
Current: 2006 Lotus Elise SC
Previous: 2008 AW E92 M3 6MT - Sold 2004 AP2 S2000 - Sold |
05-15-2010, 03:07 AM | #7 |
Scared money don't make money.
68
Rep 1,448
Drives: 2009 E92 M3 DCT
Looks great Tom . I'm going to cruise by in the next week or two to have these installed. Can you PM the pricing?
Powerbeast, your car is looking really clean....HRE, Brembo, Arkym, .
2009 E92 M3/DCT/Alpine White/Fox Red/Carbon Leather OE Tuned 402 whp & 303 wtq/Gintani X-pipe/MXP Axle Back/Rogue Pulley/AFE Stage 2/Cosmetics By IND & EAS HUGE THANKS: Gintani, OE Tuning, and EAS |
05-15-2010, 06:44 AM | #8 |
Rep 1,504
Those look great! Does the pre-LCI harness just plug into the new lights or is there an adapter that goes between the factory plug and the new taillight? Is there a place to get the coding done in DFW Texas?
Great work!
'09 E92 M3 6MT | Alpine White | Black Leather | EDC | CL Trim | 19s
'03 E46 330i 6MT | Electric Red | Black Leather | ZSP | Bi-Xenons |
05-15-2010, 12:51 PM | #11 | ||||
8312
Rep 18,880
Drives: BMW
Correct - as long as they have a complete understanding of CIP programming, which most autologic shops do. Quote:
Good news: No PnP harness is required Bad news: A post-LCI trunk is also needed due to the new shape of the taillamps. Coding is still required for proper operation.
05-15-2010, 08:20 PM | #13 |
www.ryandalziel.com
24
Rep 208
Why didnt you guys mention the dash code faults before. I bought the PNP harness from you and the tail lights from my dealer now I read this and there is no local autologic shops. Now what am i meant to do?
05-15-2010, 08:25 PM | #14 | |
8312
Rep 18,880
Drives: BMW
It's actually been mentioned quite a few times while development was being performed - each step and results were explained along the way. Please PM me your full name so I can locate a technician in your area and get you coded up.
05-15-2010, 08:31 PM | #15 |
www.ryandalziel.com
24
Rep 208
I sent you three PM's yesterday and told me that you knew of no techs in Orlando and to check the autologic website myself. Unless I am mistaken I only read that there would be bulb check flickering. I never read anything about dash faults.
05-15-2010, 08:51 PM | #16 | |
8312
Rep 18,880
Drives: BMW
Have you called autologic to see if there is a technician in your area that can assist?
05-15-2010, 09:02 PM | #17 |
www.ryandalziel.com
24
Rep 208
I dont read e90post since i have an E92. The post you posted on M3Post was this - http://www.m3post.com/forums/showthread.php?t=382162 and on this you edited post #1 to read "Edit: Coding from an independent with an Autologic programmer will be required to fully remove disable BulbCheck. Coding has been completed, let me know if you need in-house coding from us or would like us to direct you to a local. Lighting assemblies and PnP harness are not returnable."
This doesnt mention faults on the dash, only that we would have flickering. And you edited that the PNP and lights are not returnable after this post was written. |
05-15-2010, 09:09 PM | #18 |
Rep 6,919
So these can't be coded at the dealer?
2022 Dravit/Fiona M3cx - Dinan midpipe w/VC, NW Carbonhaus CF, AST Springs, FC Spacers...more to come!
2016 Indi F80 M3 - SMB|Amaro | Mode Carbon | ESS | Akra EVO | KW HAS...SOLD 2012 MR e92 M3 DCT, ESS SC, Brembo BBK, BBS FI... GONE but not forgotten! 2008 AW e92 M3 6MT, ESS SC, BBS LM's...SOLD! |
05-15-2010, 09:13 PM | #19 | |
8312
Rep 18,880
Drives: BMW
I also want to touch on your last statement, since it implies we are dishonest. We never "edited" a page after your purchase was made - this was standard policy from the beginning on this item. However as stated before: you still require coding for proper operation of the lamps - this is a move you need to make in order to get the situation resolved. If your technician should have questions prior to coding - I am here to help. If you should have any further questions or concerns or feel the need to vent - please PM or email me directly. Please understand I am on your side and do not have an agenda to ruin your weekend. BMW dealers do not have access to the proper procedures to make this work. This may change with the release of the BlackLines if LED-based.
05-16-2010, 11:49 AM | #21 |
Rep 1,504
Tom,
Could you please post some images of the wiring harness piece that you have made? Great product! Thanks!
05-16-2010, 12:47 PM | #22 | |
chris
280
Rep 12,144
i would like to see the how the wiring harness looks like and where you placed it.
Current: 2013 F10 M5 & 2016 Mini JCW 2013 GLK350 (gone), 997.1 GT3RS (gone), 2009 WRX STI (gone), e92 M3 (gone) |
