01-02-2012, 03:21 PM | #1 |
Rep 4,033
There's been a lot of interest on this forum with regards to performance #'s, below is a list so you can reference results. I would like to give a big Thank You to Divexxtreme for his help and support.
If you'd like to have a E9X M3 time added to the list, email the raw, unedited .dbn (Performance box or Drift Box) or .vbo (V-Box) file to affinityf@aol.com or Admin@Mr5Racing.com. Also include a list of all the modifications, what fuel was used, and tires. Only GPS based computer/accelerometer times from Performance Box, Drift Box, or V-Box equipment will be accepted for the M3post list. All submitted data must be reviewed for accuracy and approved before it will be listed. The maximum allowed downhill slope over the course of the run is 3.00%. Any run that exceeds 3.00% will not be added. Only 1 entry per car will be allowed in each section. You will be allowed additional entries, if it is two different cars, or the same car has a significantly different power setup, i.e. different or upgraded forced induction kit, running nitrous, or a built motor, there will be no exceptions to this rule. When comparing the below 60-130 and 1/4 mile results, please keep in mind that variances in temperature, humidity, road surface conditions, tire grip, and driver input can all have a measurable impact on the data. The Density Altitude "DA" entry next to each 1/4 mile time, is the approximate measurement during the time of the run. Please note all of the below E9x M3 entries were sourced from M3post Members, verified or submitted by M3post members DLSJ5, Mr.5(Moderator) or Divexxtreme. 60 -130 mph (96.5-209.2 kph): E9X Supercharged M3's 5.95 - VT3M33 / E92 M3 DCT / ESS VT4 800 - Built Motor / 97 octane / 3 shifts 5.97 - properstyle / e90m3/ no weight reduction / stock motor / stock clutches / Ess g2 blower/ e85 1050cc injectors / rk tuned/ dct / 1shift / Dragy 6.14 - DLSJ5 / E92 M3 DCT / ESS VT750 SC - Built Motor / 100 Octane / 3 shifts 6.16 - Madsex343 /E92 M3 DCT / ESS VT600 / 94 octane / 3 shifts 6.23 - Mikewads / E92 M3 DCT / ESS VT600 SC, 100shot Nitrous 3rd on/93oct/3 shifts 6.36 - Gpower / E92 M3 6-MT / Gpower SKIII SC - Built Motor / 1 shift 6.46 - M&M / E92 M3 DCT / ESS VT625 / Raised Rev Limiter / 94 Octane/ WM / 3 shifts 6.56 - Tom@EAS / E92 M3 DCT / VF620 SC / 91/100 mix / 2 shifts 6.57 - Evolve - Lost Marine / DCT E92 M3 / Evolve E625 SC / 93 Octane/Catless / 3 Shifts 6.75 - IMG / E90 M3 6-MT / ESS VT725 SC- Built Motor / 93 octane / 1 shift 6.78 - Mikewads / E92 M3 DCT / ESS VT600 SC / 93 octane / 3 shifts 6.80 - DLSJ5 / E92 M3 DCT / ESS VT625 SC / 95 octane / WM / 3 shifts 6.96 - Tightie / E92 M3 6-MT / Gintani Stage 3 SC - Built Motor / 91 octane / WM / 2 shifts 6.98 - M33 / E92 M3 DCT/ ESS VT650 SC / 93 octane/ WM / 3 shifts 7.06 - DLSJ5 / E92 M3 DCT / Gintani Stage 2 SC / 91 octane / WM / 3 shifts 7.52 - IMG / E90 M3 6-MT / ESS VT625 SC / 93 octane / 2 shifts 7.58 - Pencilgeek / E92 M3 6-MT / R46 Stroker ESS VT600 SC / 3.15 gears / 100 octane / 1 shift 8.31 - biglare / E90 M3 DCT / ESS VT575 SC / 3.62 Gears / 91 Octane / 2 shifts 8.95 - sammyrusso / E92 M3 DCT / Gintani Stage 1 SC / 91 Octane / 3 shifts 9.00 - EugeneTawain / E92 M3 6-MT / Gpower SKII SC / 91 Octane / 2shifts E9X Bolt On - N/A M3's 9.70 - Madsex343 / E92 M3 DCT / Full Bolt On's, ESS Tune / 2 shifts 10.09 - Evolve- Lost Marine / E92 M3 DCT / Evolve Stage 2 Ecu / Catless Xpipe, BMC Filter / 3 shifts 10.49 - Mijsa / E90 M3 DCT / Full Bolt On's, Tune & Cams / 3 shifts 10.71 - DLSJ5 / E92 M3 DCT / Full Bolt On's, GIAC Tune / 3 shifts F8X M3/M4 5.94 - Chris@VargasTurboTech / F82 M4 DCT / VTT Stage2 turbos / Custom BM3 flash by Dzenno / JB4 / VTT silicone charge pipes / BMS intakes / Aftermarket DP's / Catless exhaust / EOS V2 top mount PI manifold / PFS Double Shot LPFP Upgrade / VTT / Bell Air to Water intercooler / Dodson Sportsman Clutch upgrade / 100% E85 / R888 Tires / 2 shifts 6.04 - F80Paul / 2016 F80 M3ZCP DCT 2 shifts / Custom Turbos / Intakes / CP's / DP's / BM3 BEF / JB4 / 93oct + meth / stock 285/30/20 MPSS / 2 shifts 6.35 - Terry@BMS/ F80 M3 DCT / JB4 / Pure S2 Turbos / Dodson CP/ FBO / 97 Octane + WM / 3 shifts 7.12 - M4HCP/ F82 M4 DCT / HCP Tune + JB4 stacked / Eurocharged DP's / Catless / K&N/ 99ron / 3 shifts F10 M5 5.60 - allmotor_2000/F10 M5 DCT/Pure Stage 1 Upgraded Turbos/JB4/DP/95 Oct+Meth/2 shifts 6.59 - Terry@BMS /F10 M5 DCT / JB4 / BCM / BMS Intake and Charge pipes / Dodson CP's / BMW Meth / ~95 Octane / 2 shifts 6.75 - Imran@Evolve /F10 M5 DCT / Evolve Stage 2 ECU / Evolve Downpipes /Eventuri Intakes / 93 Oct / 3 shifts 7.08 - erm324 / F10 M5 DCT / JB4 Map 2 / BCM / 3 shifts, ALL BMW's compiled by M3post members - Divexxtreme & DLSJ5 4.21 - djborya / E30 325i / TC / 1-shift 4.22 - Mert Dastan / E46 M3 / TC / 1-shift 4.49 - Mert Dastan / E36 M3 / TC / 0-shifts 5.12 - Chris@HPF /E46M3 / TC / 1 shift 5.14 - Commanderwiggin / E46 M3 6MT / 6870 Custom Turbo - Built Motor / E85 / 2 shifts 5.60 - allmotor_2000/F10 M5 DCT/Pure Stage 1 Upgraded Turbos/JB4/DP/95 Oct+Meth/2 shifts 5.61 - RaceMX-M3 / E46 M3 / TC / 1 shift 5.94 - Chris@VargasTurboTech / F82 M4 DCT / VTT Stage2 turbos / Custom BM3 flash by Dzenno / JB4 / VTT silicone charge pipes / BMS intakes / Aftermarket DP's / Catless exhaust / EOS V2 top mount PI manifold / PFS Double Shot LPFP Upgrade / VTT / Bell Air to Water intercooler / Dodson Sportsman Clutch upgrade / 100% E85 / R888 Tires / 2 shifts 5.95 - VT3M33 / E92 M3 DCT / ESS VT4 800 - Built Motor / 97 octane / 3 shifts 5.97 - properstyle / e90m3/ no weight reduction / stock motor / stock clutches / Ess g2 blower/ e85 1050cc injectors / rk tuned/ dct / 1shift / Dragy 5.98 - Terry@BMS / 2008 135i 6AT / JB4 Tune / FFTEC Turbo / OEM 6.04 - F80Paul / 2016 F80 M3ZCP DCT 2 shifts / Custom Turbos / Intakes / CP's / DP's / BM3 BEF / JB4 / 93oct + meth / stock 285/30/20 MPSS/ 2 shifts 6.07 - M&M / E30 325is / TC / 1 shift 6.14 - DLSJ5 / E92 M3 DCT / ESS VT750 SC - Built Motor / 100 Octane / 3 shifts 6.16 - Madsex343 /E92 M3 DCT / ESS VT600 / 94 octane / 3 shifts 6.23 - Mikewads / E92 M3 DCT / ESS VT600 SC, 100shot Nitrous 3rd on/93oct/3 shifts 6.28 - Captain Insano/ E92 335I 6MT / Vishnu Procede+OpenFlash Tablet - Vishnu/FFTEC VFF900 Twin Scroll 6466 - Full exhaust, FMIC, Vishnu PWM Methanol, ERC race gas, Toyo R888 / 1 shift 6.35 - Terry@BMS/ F80 M3 DCT / JB4 / Pure S2 Turbos / Dodson CP/ FBO / 97 Octane + WM / 3 shifts 6.36 - Gpower / E92 M3 6-MT / Gpower SKIII SC - Built Motor / 1 shift 6.40 Jerry@Jpworkz / 2009 335i 6AT / JB4 Tune / JPworkz 6466 Kit / OEM / Full Weight 6.46 - M&M / E92 M3 DCT / ESS VT625 / Raised Rev Limiter / 94 Octane/ WM / 3 shifts 6.48 - Shiv@Vishnu/ E92 335I 6MT / Single Turbo upgraded / 1 shift 6.56 - Tom@EAS / E92 M3 DCT / VF620 SC / 91/100 mix / 2 shifts 6.57 - Evolve - Lost Marine / DCT E92 M3 / Evolve E625 SC / 93 Octane/Catless / 3 Shifts 6.59 - Terry@BMS /F10 M5 DCT / JB4 / BCM / BMS Intake and Charge pipes / Dodson CP's / BMW Meth / ~95 Octane / 2 shifts 6.75 - IMG / E90 M3 6-MT / ESS VT725 SC- Built Motor / 93 octane / 1 shift 6.75 - Imran@Evolve /F10 M5 DCT / Evolve Stage 2 ECU / Evolve Downpipes /Eventuri Intakes / 93 Oct / 3 shifts 6.78 - Mikewads / E92 M3 DCT / ESS VT600 SC / 93 octane / 3 shifts 6.80 - DLSJ5 / E92 M3 DCT / SC / 3-shifts 6.80 - TaZaM3 / E46 M3/ TC / 1 shift 6.86 - ST06M3 / E46 M3 / TC / 1 shift 6.88 - CupertinoSteve / E92 335I Auto /Alpina Flash / Vishnu/FFTEC ST 58mm / Full exhaust, FMIC, Vishnu PWM Meth, Race Gas, MT DR's / 2 shifts 6.95 - WarrenM / 335i Coupe / *Nitrous / 2 shifts 6.98 - M33 / E92 M3 DCT/ ESS VT650 SC / 93 octane/ WM / 3 shifts 7.06 - DLSJ5 / E92 M3 DCT / Gintani SC / 3 shifts 7.12 - M4HCP/ F82 M4 DCT / HCP Tune + JB4 stacked / Eurocharged DP's / Catless / K&N/ 99ron / 3 shifts 7.42 - Darkhold / F20 M135i / Pure Turbo Stage 2 - BMS JB4 Stage 2 - Wagner Decat - Wagner EVO2 Competition FMIC - Fuel-IT LPFP Stage2 Upgrade - Fuel-IT TBI Kit 7.52 - IMG / E90 M3 6-MT / SC / 2 shifts 7.86 - Maros / E46 M3 / SC / 1 shift 7.96 - WedgePerformance / E92 335i Sport AT / HEXON RR550 / TFT Intake / Alpina Flash / MOTIV PI / Fuel-IT Stg3 Hulk / E85 / 1 shift / Full Weight & Stock 18's 8.31 - biglare / E90 M3 DCT / SC / 2 shifts 8.39 - Blue Arrow / E60 M5 SMG / Tune, 8700rpm limit / Headers / Intake / 2 shifts 8.59 - Dr Jitsu / E46 M3 / SC / 1 shift 8.67 - DLSJ5 / E46 M3 / SC / 2 shifts 8.81 - E46bhp / E46 M3 / SC / 1 shift 8.95 - sammyrusso / E92 M3 DCT / SC / 3 shifts 9.08 - hiboostingm3 / E36 M3 / TC / 2 shifts 9.15 - Duschanio-Imran@Evolve / E60 M5 / SMG / Primary Decat / Evolve Stage 3 Tune / 93 octane / 2 shifts 9.15 - Mr. 5 / 335i Sedan / 1-shift 9.18 - canberkd /BMC filters with rpi scoops/ 93 octane/ 7*C (temp) from istanbul/ 2 shifts 9.62 - M6koo / M6 SMG (intake, exhaust, pulley, tune) / 2-shifts 9.66 - Fanatic7 / E46 M3 / SC / 2 shifts 9.87 - Mspired / E46 M3 / SC / 1 shift 10.05 - Imran@Evolve / F85 X5M Catless DP, Evolve Stage 2 ECU (Power limited to 730 BHP), 93 Octane / 3 shifts 10.3 - Stock M6 / 2 shifts 10.4 - RaceMX-M3 / Stock E60 M5 / 2 shifts 10.3 - Stock M6 / 2 shifts 10.4 - RaceMX-M3 / Stock E60 M5 / 2 shifts 10.5 - fivaxis / E36 M3 / TC / 2 shifts 10.8 - DLSJ5 / E92 M3 DCT/ Bolt-Ons 11.0 - slcook54 / E36 M3 / TC / 3 shifts 11.2 - M&M / Chipped 335i / 1 shift 12.9 - 05SCM3 / E46 M3 / SC / 2 shifts 12.9 - Stock E92 M3 Coupe 13.7 - IDZ21 / Stock E46 M3 (freak car) / 1 shift 14.3 - hiboostingm3 / Stock E39 M5 / 1 shift Here's how we compare with others, courtesy of M3post member Divexxtreme: 3.04 - Underground Racing TT Gallardo E-Gear (Bob Helms' car) / 1-shift 3.31 - AMS Alpha 12 GT-R 3.33 - Divexxtreme / Switzer R1KX GT-R 3.53 - Underground Racing TT Gallardo Nera 6-MT / 2-shifts 3.61 - HoustonT / Underground Racing TT Gallardo 6-MT / 1-shift 3.85 - Switzer / R1K GT-R / 2-shifts 3.92 - Powell / 996tt / RWD / 1-shift 3.95 - 1swtride / C6 Z06 / built 427, YSI blower, 1080rwhp, auto 3.96 - KPG / 996tt / RWD / 0-shifts 4.09 - Acicchelli / TT Gallardo / 1-shift 4.14 - Keithta / 997TT AWD / 1-shift 4.16 - Emre@Esmotor /997TT AWD TIP 4.21 - DJborya / BMW 325i / S52 with 80mm turbo / 1-shift 4.22 - Besiktas / 997TT AWD TIP 4.23 - TwinTurboM3 / TT E46 M3 with nitrous / 0-shifts (4th gear only) 4.25 - dk996tt / 997TT AWD / 1-shift (stock internals) 4.25 - art4iza / 996tt / RWD / 0-shifts 4.43 - edelectra / 997TT AWD / 1-shift (stock internals) 4.48 - vegasGTR / GTR ~812whp 4.49 - TwinTurboM3 / TT E36 M3/ 0-shifts 4.52 - jbsteven / SC&TT Ford GT 994 rwhp / 1-shift 4.53 - HoustonT / 880 rwhp Supra / 1-shift 4.55 - Greg-TT / 770awhp GT-R 4.62 - Markski / 996tt / RWD / 2-shifts 4.67 - Divexxtreme / 996tt / RWD / 2-shifts 4.70 - SCvette00 / Switzer E900 GT-R / 824 awhp 4.81 - Joetwint / 996tt / RWD / 2-shifts 4.85 - topgun / 996tt / AWD / 2-shifts 4.89 - Powell / 996tt / AWD / 1-shift (stock internals) 4.87 - Oz / Supra / 1-shift 4.88 - 1SwtRide / C6 Z06 / 1,080rwhp 4.95 - Divexxtreme / 996tt / GT2 / 2-shifts 5.6 - Bugatti Veyron 5.61 - RaceMX-M3 / E46 M3 HPF Stage 2.5 Turbocharged / 1-shift 5.74 - Divexxtreme / Supercharged C6 Z06 / 1-shift 6.59 - McLaren MP4-12C - Stock - With Performance Upgrade 6.59 - Dads C63 / Bolt-On C63 AMG + 125 shot of Nitrous 6.65 - Renntech SLR 6.67 - Madsex343 / 997tt / APR Tune - Bolt On's / 2-shifts 6.73 - FikseGTS / Ford GT with pulley and Heffner tune 6.86 - STO6M3 / E46 M3 HPF Stage 2 Turbocharger - 6MT 6.89 - C5 Z06TT (APS Turbo, no cats, stock muffler, 573 rwhp @ 9.5 psi) / 1-shift 6.95 - hotrod182 / 335i w/ JB3 piggyback ECU and Nitrous / 2-shifts 7.0 - Ferrari Enzo 7.05 - Divexxtreme / 2010 GT-R, Switzer Bolt Ons and Tune 7.06 - C6 Z06; intake, tune, headers, cam, no cats, 560 rwhp, 2-shifts 7.25 - Stock 997 GT2 / 1-shift 7.3 - Porsche Carrera GT 7.24 - Stock SLR 7.59 - dzenno / '08 335i twin turbo / 1- shift 7.75 - Shelby GT500, Kenne Bell, 700+ rwhp, 1-shift 7.84 - ImolaMpower / BMW E46 M3 6-MT / Gintani Stage 2 SC / WM - MS109 7.85 - Stock LP640 / 2-shifts 7.86 - Divexxtreme / Stock C6 Z06 / 2-shifts 7.8 - Chevrolet Corvette ZR1 7.86 - Maros / E46 M3 / SC / 1 shift 8.08 - Dads C63 / Bolt-On C63 AMG 8.16 - 930chas / E55 AMG 8.59 - Dr Jitsu / Supercharged M3 / 1-shift 8.67 - DLSJ5 / Supercharged E46 M3 SMG / 2-shifts 8.81 - E46bhp / E46 M3 / SC / 1 shift 9.15 - Mr. 5 / 6MT 335i Sedan / 1-shift 9.08 - hiboostingm3 / E36 M3 / TC / 2 shifts 9.4x - stock 2012 GT-R 9.42 - stock 2010 CTS-V / 1-shift 9.47 - Audi S4 Stage 3 on E85 9.62 - M6koo / M6 SMG (intake, exhaust, pulley, tune) / 2-shifts 9.66 - Fanatic7 / E46 M3 / SC / 2 shifts 9.87 - Mspired / E46 M3 / SC / 1 shift 9.79 - sammyrusso / stock C63 with P31 package 9.99 - Divexxtreme / stock 2010 GT-R 10.13- Stock F430 / 3-shifts 10.3 - Stock M6 / 2 shifts 10.4 - RaceMX-M3 / Stock E60 M5 / 2 shifts 10.87 - Audi B8 S4 / intake,exhaust,tune,pulley, 6-MT 11.81- Stock Lexus IS-F / Sequential 12.9 - Stock E92 M3 Coupe 13.7 - Stock E46 M3 (freak car) / 1 shift For those that don't follow 1/4 mile drag racing; E.T. (Elapsed Time) is primarily a derivative of the launch, while Trap Speed (MPH achieved at the end of the run) is primarily a derivative of the amount of power being put to the ground on that specific track, that specific day. Trap Speed can be used tell you almost exactly how much hp your car is making at the wheels, assuming you use the correct calculations. If you'd like a E9X M3 run to be added to the list, please provide proof of the run. Only 1/4 mile times from timeslips and/or video (preferably both) will be accepted for this list. No GPS based, datalogger 1/4 mile times will be accepted. E9X M3's Supercharged 10.24 @ 140.24 MPH - 1.75 60' - filinm3/E92 M3 DCT/ Built Motor / ESS VT4 / 96 octane / Hoosier DR 10.38 @ 136.04 MPH - 1.66 60' - SalM - Gintani Stage X+ / C85 / Mickey Thompson ET Street R / DA -240' 10.46 @ 135.13 MPH - 1.70 60' - binh513 / E92 M3 DCT / ESS VT 625 @ 10psi/ Water/Ice Tank / 93 / Weight Reduction / DR's' / DA -1380' 10.54 @ 132.66 MPH - 1.74 60' - Evolve - LostMarine / DCT E92 M3 / Evolve E625 SC / 93 Octane/Catless / DR's / -150lbs W.R. / DA -470 10.65 @ 131.79 MPH - 1.72 60' - 1SICKM / E92 M3 DCT / ESS VT 625 / 93/100 mix octane / 150 lbs. Weight Reduction /Nitto DR's / DA -1548' 10.69 @ 129.38 MPH - 1.63 60' - Mike@VAC, (Klevis@VAC - Driver) / E92 M3 DCT / VF620 SC / 93 Octane / MT ET DR's / DA -1300' 10.81 @ 135.13 MPH - 1.80 60' - DLSJ5/E92 M3 DCT/ESS VT3 750 / 96 octane / BFG / MDM / DA - +270' 10.84 @ 131.60 MPH - 1.82 60' - M33 / E92 M3 DCT/ ESS VT650 SC / 93 octane/ R888 / MDM / DA -1548' 10.87 @ 131.40 MPH - 1.87 60' - Mikewads / E92 M3 DCT / ESS VT600 - 100 shot / 93/100 Mix / MT ET DR's / DA +147' 10.91 @ 129.21 MPH - 1.73 60' - Smokeyob / E92 M3 DCT / ESS VT625/ Akrapovic Evolution / 93 Oct / MT ET DR's / DA -755' 11.00 @ 129.23 MPH - 1.84 60' - EAS (Mr. 5 driver) /E92 M3 DCT / ESS VT625 / Akra Exhaust/ 98 Oct / ~175 lbs. Weight Reduction / Hoosier DR's / DA +415' 11.158 @ 126.13 MPH - 1.83 60' - Properstyle / E90 M3 DCT / ESS VT625 / BPM tune /Full stock weight/ 93 OCT/GTS DCT (launches too low) / R888R 295/30/19s / DA +1500' 11.20 @ 127.30 MPH - 1.90 60' - M&M / E92 M3 DCT / ESS VT625 / Raised Rev Limiter / WM / MT ET DR's / DA +4500' 11.24 @ 127.55 MPH - 1.87 60' - Sal@Autocouture / E92 M3 DCT / ESS VT650 / 93 octane / Nitto NT05 / DA +800' 11.29 @ 126.70 MPH - 1.84 60' - akh23456 / E90 M3 DCT /AA Stage 2 / 93 Octane / WM / Street tires / DA -1600' 11.30 @ 129.34 MPH - 1.97 60' - DLSJ5 / E92 M3 DCT / ESS VT625 / 95 Octane / WM / Nitto DR's / DA +1300' 11.41 @ 131.67 MPH - 2.06 60' - DLSJ5 / E92 M3 DCT / Gintani Stage 2 / MS109/ WM / BFG DR's / DA +1166' 11.48 @ 129.01 MPH - 2.10 60' - dnotorious / E90 M3 DCT / AA Gen 2 level 3 / FBO / 94 Octane / Street Tires / DA -20 11.61 @ 123.17 MPH - 1.83 60' - Smokeyob / E92 M3 DCT / ESS VT600 / Akrapovic Evolution / 93 Oct/ Pilot Super Sport / DA +1000'?? 11.68 @ 122.44 MPH - 1.87 60' - 1SICKM / E92 M3 DCT / ESS VT 535 / 93 octane / Street tires / DA -1600' 11.71 @ 132.26 MPH - 2.14 60' - ERM324 / E92M3 DCT / ESS VT625 / 100 octane / Nitto DR's / DA -700' 11.94 @ 118.66 MPH - 1.93 60' - prodigymb / E92 M3 6-MT / ESS VT600 / 93 octane / DR's / DA -1100' E9X M3's Supercharged in order of trap speed 10.29 @ 140.64 MPH - 1.70 60' - filinm3/E92 M3 DCT/ Built Motor / ESS VT4 / 96 octane / Hoosier DR 10.38 @ 136.04 MPH - 1.66 60' - SalM - Gintani Stage X+ / C85 / Mickey Thompson ET Street R / DA -240' 10.46 @ 135.13 MPH - 1.70 60' - binh513 / E92 M3 DCT / ESS VT 625 @ 10psi/ Water/Ice Tank / 93 / Weight Reduction / DR's' / DA -1380' 10.81 @ 135.13 MPH - 1.80 60' - DLSJ5/E92 M3 DCT/ESS VT3 750 / 96 octane / BFG / MDM ON / DA - +270' 10.61 @ 133.33 MPH - 1.82 60' - Evolve - LostMarine / DCT E92 M3 / Evolve E625 SC / 93 Octane/Catless / DR's / -150lbs W.R. / DA -470 11.71 @ 132.26 MPH - 2.14 60' - ERM324 / E92M3 DCT / ESS VT625 / 100 octane / Nitto DR's / DA -700' 10.85 @ 132.10 MPH - 1.83 60' - M33 / E92 M3 DCT/ ESS VT650 SC / 93 octane/ R888 / DA -1548' 10.65 @ 131.79 MPH - 1.72 60' - 1SICKM / E92 M3 DCT / ESS VT 625 / 93/100 mix octane / 150 lbs. Weight Reduction /Nitto DR's / DA -1548' 11.41 @ 131.67 MPH - 2.06 60' - DLSJ5 / E92 M3 DCT / Gintani Stage 2 / MS109/ WM / BFG DR's / DA +1166' 11.45 @ 131.63 MPH - 1.99 60' - Evolve - Lost Marine / DCT E92 M3 / Evolve E625 SC / 93 Octane/Catless / R888's / DA -500 10.87 @ 131.40 MPH - 1.87 60' - Mikewads / E92 M3 DCT / ESS VT600 - 100 shot / 93/100 Mix / MT ET DR's / DA +147' 11.07 @ 130.40 MPH - 1.84 60' - EAS (Mr. 5 driver) /E92 M3 DCT / ESS VT625 / Akra Exhaust/ 98 Oc / ~175 lbs. Weight Reduction / Hoosier DR's / DA +415' 10.69 @ 129.38 MPH - 1.63 60' - Mike@VAC, (Klevis@VAC - Driver) / E92 M3 DCT / VF620 SC / 93 Octane / MT ET DR's / DA -1300' 11.30 @ 129.34 MPH - 1.97 60' - DLSJ5 / E92 M3 DCT / ESS VT625 / 95 Octane / WM / Nitto DR's / DA +1300' 10.91 @ 129.21 MPH - 1.73 60' - Smokeyob / E92 M3 DCT / ESS VT625/ Akrapovic Evolution / 93 Oct / MT ET DR's / DA -755' 11.48 @ 129.01 MPH - 2.10 60' - dnotorious / E90 M3 DCT / AA Gen 2 level 3 / FBO / 94 Octane / Street Tires / DA -20 11.24 @ 127.55 MPH - 1.87 60' - Sal@Autocouture / E92 M3 DCT / ESS VT650 / 93 octane / Nitto NT05 / DA +800' 11.20 @ 127.30 MPH - 1.90 60' - M&M / E92 M3 DCT / ESS VT625 / Raised Rev Limiter / WM / MT ET DR's / DA +4500' 11.29 @ 126.70 MPH - 1.84 60' - akh23456 / E90 M3 DCT /AA Stage 2 / 93 Octane / WM / Street tires / DA -1600' 11.158 @ 126.xx MPH - 1.83 60' - Properstyle / E90 M3 DCT / ESS VT625 / BPM tune /Full stock weight/ 93 OCT/GTS DCT (launches too low) / R888R 295/30/19s / DA +1500' 11.61 @ 123.17 MPH - 1.83 60' - Smokeyob / E92 M3 DCT / ESS VT600 / Akrapovic Evolution / 93 Oct/ Pilot Super Sport / DA +1000'?? 11.68 @ 122.44 MPH - 1.87 60' - 1SICKM / E92 M3 DCT / ESS VT 535 / 93 octane / Street tires / DA -1600' 11.94 @ 118.66 MPH - 1.93 60' - prodigymb / E92 M3 6-MT / ESS VT600 / 93 octane / DR's / DA -1100' E9X M3's N/A - Bolt On's 11.59 @ 119.07 MPH - 1.73 60' - SalM - Bolt On's, RK-Tunes / E85 / R888R's 11.60 @ 119.76 MPH - 1.78 60' - gzim335 -Gintani tuned / E85 / R888 11.88 @ 118.xx MPH - 1.81 60' - DLSJ5 - Bolt On's, GIAC tune / 91/100 Mix / Nitto DR's 12.00 @ 116.15 MPH - 1.93 60' - erm324 - Bolt On's, OE tune / 93/110 Mix / DR's 12.20 @ 113.62MPH - 1.91 60' - E92_carbonm3 - Bolt On's, OE tune / 93/ Street tires 12.29 @ 115.63 MPH -1.95 60' - Cptn Mo 307 - Bolt On's, OE tune / 93/100 Mix / Street Tires 12.51 @ 115.89 MPH -1.98 60' - M3DCTBT - Stock X-pipe, OE tune, Muffler /93 octane / MDM Mode / PS2's 12.85 @ 110.56 MPH - 1.94 60' - LSB.BETZY - Stock DCT E9X M3's N/A - Bolt On's - In order of trap speed 11.68 @ 122.87 MPH - 1.83 60' - gzim335 -Gintani tuned /E85 / R888 11.59 @ 119.07 MPH - 1.73 60' - SalM - Bolt On's, RK-Tunes / E85 / R888R's 11.88 @ 118.xx MPH - 1.81 60' - DLSJ5 - Bolt On's, GIAC tune / 91/100 Mix / Nitto DR's 12.00 @ 116.15 MPH - 1.93 60' - erm324 - Bolt On's, OE tune / 93/110 Mix / DR's 12.51 @ 115.89 MPH -1.98 60' - M3DCTBT - Stock X-pipe, OE tune, Muffler /93 octane / MDM Mode / PS2's 12.29 @ 115.63 MPH -1.95 60' - Cptn Mo 307 - Bolt On's, OE tune / 93/100 Mix / Street Tires 12.20 @ 113.62MPH - 1.91 60' - E92_carbonm3 - Bolt On's, OE tune / 93/ Street tires F8X M3/M4 10.34 @ 133.82 MPH - 1.68 60' - Maximumpsi / F80 M3 DCT / JB4, MP ECU / Pure S2 Turbos / MP Intake, DP's, Exhaust / EOS Intercooler / Dodson CP / Drag Radials / DA ~600' 10.89 @ 132.56 - 1.76 60' - SpeedDemon7 / F80 DCT / JB4 / TurboLabs Big Turbos /BMS Intake / VRSF Chargepipes / Gintani DP / M4 GTS DCT FLASH / NT555R 305 35 18 / METH CM7 BMS 11.35 @ 135.50 MPH - 2.19 60' - Terry@BMS / F80 M3 DCT / JB4 / Pure S2 Turbos / Dodson CP/ FBO / 97 Octane + WM / Nitto 555R / DA +2500' F10 M5 9.99 @ 140.74 MPH - 1.57 60' - allmotor_2000/F10 M5 DCT /Pure Stage 1 Upgraded Turbos /BMS-JB4/ DP/ 95 Oct+Meth / Weight Reduction / Water Tank Intercooler/ MT Drag Radials / DA +625' 11.49 @ 129.16 MPH - 2.08 60' - Imran@Evolve - F10 M5 /Evolve Stage 2 ECU / Downpipes / Eventuri Intakes / 93 Octane, Street Tires
16 F82 M4 DCT - ZCP - JB4 - 556WHP / 570WTQ
08 E92 M3 DCT - Bolt Ons - 60-130MPH 10.71s - 11.88 @ 118MPH - 377WHP ESS VT2-625 SC 60-130MPH 6.80s - 11.30 @ 129.3 MPH 586WHP / 379WTQ ESS VT3-750 - 60-130MPH 6.14s - 10.81 @ 135.13 MPH 690WHP/463WTQ Shift-S3ctor E92 M3 - 1/2 Mile Trap Speed WR - 174.13 MPH Last edited by DLSJ5; 12-10-2020 at 06:27 PM.. |
01-02-2012, 03:33 PM | #2 |
10869
Rep 27,640
this is awesome. good to see Warren on that list
BEFORE YOU BUY YOUR NEXT BMW, EMAIL OUR GUY KOTE FIRST! Kote M Sales:Kotem@bmwofcamarillo.com Cell:805-368-9101 vipfinance@bmwofcamarillo.com for warranties! |
01-02-2012, 03:34 PM | #3 |
Modder Raider
759
Rep 8,633
Drives: M3
This is good stuff.
I'm going to sticky it.
e36 M3 Coupe, e36 325i Sedan
e90 335i--SOLD Best 60-130-------------9.15 Seconds------------------WWW.MR5RACING.COM |
Maxf80M3174.00 |
01-02-2012, 03:37 PM | #4 |
Rep 4,033
Thanks Broski, very happy that you wanted to work on this with me!
08 E92 M3 DCT - Bolt Ons - 60-130MPH 10.71s - 11.88 @ 118MPH - 377WHP ESS VT2-625 SC 60-130MPH 6.80s - 11.30 @ 129.3 MPH 586WHP / 379WTQ ESS VT3-750 - 60-130MPH 6.14s - 10.81 @ 135.13 MPH 690WHP/463WTQ Shift-S3ctor E92 M3 - 1/2 Mile Trap Speed WR - 174.13 MPH |
Maxf80M3174.00 |
01-02-2012, 03:40 PM | #6 |
Rep 4,033
Cool deal!
01-02-2012, 03:43 PM | #7 |
Rep 4,033
Warren is one of my favorite BMW enthusiasts, his cars have always been impressive and he has shared so much solid info for 335 owners, he just goes out and does it.
01-02-2012, 04:37 PM | #9 |
Rep 3,157
nice job D
Past: Gintani stage3 M3, Cayman GTS present: Porsche 993RWB, 964RS America,996 cupcar, 964 turbo 3.6,Macan Turbo,997GT2,930 turbo,i3, MINI JCW |
01-02-2012, 04:39 PM | #10 |
10869
Rep 27,640
Yea Warren is the Man
01-02-2012, 04:53 PM | #11 |
Rep 4,033
Thanks guys!
01-02-2012, 05:37 PM | #12 |
JOSH SHOKRI.
524
Rep 5,881
Drives: 991 GT3RS, 964, Raptor
Loving the list Great job Drew!
I need to go out and beat my time with some better tires.. Too much damn tire spin
Current: 16 991 GT3RS , 91 964 C2, 17 Raptor | Past: 2015 991 GT3, 2015 i3,15 YMB F80 M3, 13 E92 M3 DCT, 08 E92 M3 6MT, 07 E60 M5, 02 E46 M3
Instagram: @josh_speeddistrict #SpeedDistrict @SpeedDistrict |
01-02-2012, 05:42 PM | #13 |
Rep 4,033
Thanks Josh, it was your 1st attempt, and it's a good one. Your 1st shift was literally right at 60mph as well, it took about .3 off your time, you have a low 6 s car there on that stretch of road with some good traction, time to go out and give it another try!
01-02-2012, 06:09 PM | #14 |
Rep 5,264
Drives: 2008 E90M3
subscribed!
- Jason P
:Have: 08 E90M3, Varis VRS Front Lip, LS3, ESS Supercharger, Arqray Exhaust, Neez Wheels :Want: VRS Carbon GT Wing & Cooling Bonnet, LCI Taillights :Videos: EnvyRidesTV, GPR 1, GPR 2, GPR 3, ///MFEST |
01-02-2012, 06:55 PM | #16 | |
Rep 5,264
Drives: 2008 E90M3
from what i've noticed through the years of being on forums... you've always topped the lists and every car you own is made FAST. so much for you sir. just had to say that.
- Jason P
01-02-2012, 06:57 PM | #17 |
Rep 4,033
Thanks Brother, this type of list all started with your idea and all of your hard work, thanks again for your help and support.
01-03-2012, 09:23 AM | #18 |
Rep 933
Nice one Drew!
ps. I did not drive the car, Klevis did. You may want to add that somewhere. I am the interface for VAC to the forums though
Brian Casella
Sales Representative, VAC Motorsports Office: 215.462.4666 | Fax: 215.462.4667 EXT 13 | Email: brian@vacmotorsports.com |
01-03-2012, 09:30 AM | #19 |
All I do is Win... Eat Race Sleep
153
Rep 2,184
Drives: 2018 Range 2011 M3 2019 600lt
nice drew looks good man. thanks
Rs7 : 10.4 133.50 with a 1.7 60ft Toyo R888 F10 M5: 11.308 131.96 with a 1.9 60ft Street Tires E90 M3: 11.2 126.7 with a 1.8 60ft Street Tires |
01-03-2012, 11:09 AM | #20 |
Rep 4,033
Thanks Mike, revised it.
01-03-2012, 11:10 AM | #21 |
Rep 4,033
01-03-2012, 12:07 PM | #22 |
Rep 624
Nice list - about time you got one here! Hard to believe we dont have any other 6spd SC cars going to the track. My super sloppy time is almost a year old in a couple of months - I woulda though someone would have bested the 6spd time by now. Im gonna try to make another Atco trip on the E92...
