      04-04-2012, 04:20 PM   #1
Brian_VACsales
Brian_VACsales's Avatar
194
Drives: E92 M3 VF Supercharged, 135i
VAC Motorsports | 135i OS Giken Super Lock LSD 3.08 Manual Differential / Final Drive
VAC is proud to be a master stocking OS Giken dealer.
BUY NOW AT VACMOTORSPORTS.COM
OS Giken = the choice of enthusiasts and racers who want "the best" clutch type LSD available. Example: Berk Technology runs OS Giken in their famous 135i.
Up until recently, very few enthusiasts in BMW land knew the name OS Giken [pronounced (oh. ess. gee-ken)]. However they are a legendary Japanese tuner and manufacturer of super high end race parts. Sensing the BMW market was in dire need of performance differentials, OSG developed their unique LSD technology for the BMW market.
OS Giken is rapidly becoming the choice of the Porsche enthusiasts where rear engine layouts and high horsepower require perfect control and stability. The BMW racer and enthusiast can also immediately appreciate the excellence of design and performance the OS Giken offers to their vehicle from the moment they drive.
The OS Giken Super Lock LSDs are much like other clutch type LSDs in that they offer the quick, positive response that some drivers prefer vs. a gear based / torque biasing differential. Some standout features the OS Giken has involve it doing it's job better than any of its clutch type competitors:
-Extreme performance; capable of 100% locking on demand
-20 Clutchplates! Many clutch-style units only have between 4 and 8 total!
-Incredibly smooth response; suitable for comfortable daily street use
-Durable: extremely long life for both street or track use- tested to maintain performance over a vehicles entire lifespan
-Strong: nearly unbreakable - used as delivered by professional drifters and championship racers
-Precision machining; long life and ready to use out of the box, no break in required
Superior Design
-Miniaturized pressure ring and a superior spline-through-side-gear design allows for fitment of more friction plates (up to 2x as many as competitors versions), offering true 100% lock capability.
-Patented pressure ring design allows for smooth, progressive locking
-Case has a relief cut-out for the cone spring, for minimized cone-spring flexing and enhanced durability.
Superior Construction
-All components are chemically heat treated for maximum durability
-All components are constructed with high-grade steel alloy
-Gears are raw-forged for maximum strength
-Disks are precision-machined simultaneously on both sides to extremely tight tolerances
-Case is billet construction
Tunability
-Initial torque can be adjusted by using thicker / thinner cone springs
-Lock progression timing can be adjusted by using stiffer / weaker pressure ring springs
-Ramp angles can be customized by swapping the pressure ring and iron cross
-Disks can be swapped to TCD type for enhanced oil flow properties
Superior Overall Performance
-The OS LSD standard spec allows for low preload while still retaining a fully progressive 100% lock capability; basically, the vehicle will feel like driving on an open diff in slow turns / street driving, but can still transmit maximum power to the drive wheels under load.
-Operation is ultra quiet, and the progressive locking allows for smooth, predictable locking. Especially when replacing an open diff, equipping OS LSD will completely improve the driving experience while maintaining everyday drivability. With OS LSD equipped, inside wheel spin can essentially be eliminated, and throttle steering becomes unequivocal.
-Due to the precision manufacturing, high-grade materials / processes used, and superior design, no break-in period is required for OS LSD, and no rebuilds are required. OS LSD is purposefully over-engineered to offer the best performing, most durable clutch-type LSD available.
-Aside from the performance advantage and stock-like feel at slow speeds, vehicles equipped with OS LSD are more stable in all road/weather conditions, allowing for a safer driving experience.
Brian Casella
Sales Representative, VAC Motorsports
Office: 215.462.4666 | Fax: 215.462.4667 EXT 13 | Email: brian@vacmotorsports.com
      03-31-2013, 08:33 PM   #2
Brian_VACsales
194
3.08 gas, 2.56 DCT and 2.81 diesel FINAL DRIVES with Quaife ATBs and OS Giken Super Locks built and IN STOCK. :-)
Brian Casella
135i, lsd, os giken, vac motorsports
