06-29-2012, 12:48 PM | #1 |
Rep 9
Clutch delay valve - HP Autowerks
Guys,
I don't know if this topic was already posted, but... I was seeing about clutch delay valve, does anybody here have this installed??What's it for?Worth it?Difficult to install?? Thanks... |
06-29-2012, 02:54 PM | #2 |
Rep 170
Have it.
It makes the control of the clutch feel more connected with pedal movement so you eliminate that sloppy feeling of the clutch engagement as your nearing what should be full engagement. You don't get that momentary feeling like the clutch isn't grabbing when your foot has already left the clutch pedal. Completely worth it. Took me about 10-15 minutes on ramps including bleeding with a couple basic tools.
08' 135i MT || Cobb Stage 1 'Aggressive' 4.01 Map | BMS DCI | Berk Mid Pipes | Maddad Eurosport Axleback | E93 FSB | M-Sport Black on Black | CDV Delete ||
06-29-2012, 11:49 PM | #3 |
2617
Rep 2,819
Drives: e82 1M, f87 M2cs
Great info in this thread . . . You can modify your own CDV.
http://www.1addicts.com/forums/showthread.php?t=558362 |
06-29-2012, 11:55 PM | #4 |
European Editor
10589
Rep 22,992
cdv delete DIY...
06-30-2012, 01:24 AM | #5 | |
2617
Rep 2,819
Thanks! |
06-30-2012, 01:27 AM | #6 |
Rep 4,518
CDV
Guys,
Be careful here as CDV upgrade on non M cars is definitely worth doing. However, on M3 at least the CDV is full bore. Assuming 1M is the same then CDV swap out would yield little or no benefit. I upgrade to an M3 CDV on my e91 335i and difference in clutch feel was night and day. However, clutch pedal stop mod is worth doing to reduce the clutch travel. I fitted the BMS one and it's good as its got packers so as you can adjust to best suit yourself and make sure there's no dragging of the clutch. Just my 2 cents worth. Cheers, Dave |
06-30-2012, 08:37 AM | #8 |
2617
Rep 2,819
There are lots of testimonials regarding benefit on 1M. I have driven manuals for 22 years and never had one make me feel like a retard until now. (first BMW)
In the DIY thread above, there is a nice photo through the heart of the CDV, and there is definitely a restriction, possibly 1mm or so. |
06-30-2012, 10:40 AM | #9 | |
European Editor
10589
Rep 22,992
I have seen some post on the M3 forum where the early e9x M3 did not have a CDV restriction inside the adapter/valve. While later cars DID! I know M cars in the e/36, e46 and e39 M5's had a cdv. So... I think we need to see some testimonials first. But I suspect bmw puts these crappy CDV's on all their cars - including M cars. And including the 1M. This is such a worthwhile must have mod that its worth having a look! You can not tell until you get it all apart though. Even so... its worth the effort.
06-30-2012, 11:20 AM | #10 |
Rep 812
Surely a "full bore" clutch delay valve is an oxymoron? No restrection = no delay. Assuming the 1M doesn't have a CDV is somewhat at odds with the photographic and in-person evidence of many here ;-)|
2019+ BSM M2C 2011-2012: VO 1M Coupe, many toys, Evolve Stage 3. 2008-2011: 135i M Sport Le Mans Blue / Lemon / HGSL. Evolve OBD remap - 390bhp. Also in the family: X3 M40d / Audi S4 (V8)
06-30-2012, 04:38 PM | #11 |
Rep 4,518
My suggestion fella is view the parts side by side, as I did when I did the swap out.
Further, I have driven a friends 135i with the CDV deleted. Clutch felt the same as mine with M3 CDV installed. If in doubt just delete the CDV. I kept CDV as my car is still under warranty. |
06-30-2012, 05:04 PM | #12 | |
Rep 3,070
07-01-2012, 12:18 AM | #14 | |
Rep 3,094
FYI I have tapped out more than one 1M CDV so it isnt a lone data point in my experience. |
07-01-2012, 08:58 PM | #16 | |
Rep 3,164
Drives: Many
Garage List 2020 BMW M2 CS [0.00]
1994 Audi RS2 Avant [0.00] 2021 Audi RS6 Avant [0.00] 1988 BMW E30 M3 [0.00] 2011 BMW 1///M [0.00] 2017 BMW F80 M3 30 ... [0.00] 2018 Porsche 991.2 GT3 [0.00] 2015 Porsche Macan ... [0.00] 1998 Porsche 993 C4S [0.00] 1994 Lancia Delta I ... [0.00] 2008 Audi RS4 [0.00] |
OP, if you don't want to do this yourself (even though it is 1 on the 10 scale of difficulty), you can "trade-in' yours here for a 'free' one: http://www.zeckhausen.com/cdv.htm
2011 BMW E82 1///M: AW, all options; Renntech, Akrapovic, Forge, P3, RevoZ CF bits, many mods
1988 BMW E30 M3: Hennarot, S14, stock 2018 Porsche 991.2 GT3: PtS, CXX, LWBS, PCCB 1998 Porsche 993 C4S: Zenith Blue, last aircooled widebody, Bilstein PSS10, Fister II + Fabspeed exhaust 2008 Audi B7 RS 4: Sprint Blue, Audi Exclusive Euro Bucket Interior, Premium+Titanium, many mods |
07-01-2012, 09:34 PM | #17 |
2617
Rep 2,819
Just did this today, what a difference!! I coupled the lines together and intended to leave the who CDV out. Ocne I had it out, the valve tapped out of the housing easily, so I put the gutted valve back in the keep the unmodified look.
FYI, the 1M clutch bleeder is an 11mm. The DIY called for a 10mm wrench. Those who have incomplete sets of tools (like me) will want to know that before starting. Fortunately I had an 11mm. There is definitely NOT enough room in there to use a monkey wrench. |
07-03-2012, 12:36 AM | #18 | |
Supreme Allied Commander
3848
Rep 54,378
Drives: F80 M3
clutch, delay, valve |
