03-25-2013, 01:34 AM | #1 |
Rep 698
DIY Tri-Stitch Shift Boot
I like the look of the Tri-Stitch Shift Boot, but I could not justify the price of it. I figured I could do it myself. Well, here it is, at a cost of $12 and about 3 hours of time. You can use the same instructions for the e-brake boot. It will take a little longer because there are more stitches.
What you will need: 1. Needle - Use a thicker needle to go through leather. You can buy a leather needle. I used a needle for sails which did the trick. 2. Thread - The hardest part is matching the colors. I went to the sewing store and brought my M-Power Zip Up. I matched the colors to that. I also used a slightly thicker thread to make the stitches "pop" a bit. You can use a thinner thread. Personal choice. 3. Small screw-driver. 4. Glue - to reglue the base to the boot. I acutally used Krazy Glue which worked fine. 5. Option - A Thimble. Seriously. Step #1 - Remove the Shift Boot. I will not repeat the instructions, but they can be found here http://www.m3post.com/forums/showthread.php?t=312715 Step #2. Remove the base from the leather. It is glued on, but a I just pried it off with a tiny screwdriver. Start with the tabs and then work your way around from the corners. When it is off is should look like this: Step 3. - Remove the stitches. Be sure to go under the stitch and be careful not to poke a hole in the leather. The stitches will need to be removed from both the outside and inside of the boot. Step 4. - Sew. Use the holes left over from when the stitches removed. The trick is to start from the inside of the boot with the SECOND hole and sew it backward to the first hole. Then go underneath up through hole 3 and back through the hole. Then up through hole 4 and back through 3 and so on. Sometimes it can be hard to push the needle through the leather, that's why I suggested a thimble. Also if it is really hard, check to make sure there is no black thread stuck in the holes. See the pictures below. And Backward through previous hole... Step 5. Repeat otherside with light blue. Step 6. Now zig-zag the dark blue. Note that these stitches DO NOT go through the holes (other than at the two ends), just under the light blue and red thread in an every other pattern. Note, I chose not to pull the zig-zags tight (like the steering wheel), but you can. Again, preference. When it is done, it should look like this: Step 7. Repeat on the other sides. Step 8. Re-glue the boot to the base. Use a nail file or sandpaper to rough up the base an little so the glue grips. I used Krazy Glue and it worked fine. Step 9. Re-install and drive.
2011 E93 - Space Gray - 6MT/Silver Novillo/
OE Tuning/Gruppe M Intake/ACS Springs/Vorsteiner CF Type I Rear Diffuser/Textured Matte Black Custom Powdercoated OEM 359s/Painted Reflectors/Matte Grille, Hood Vents and Side Markers/Arqray Race Exhaust/MS Pulley |
03-25-2013, 05:04 AM | #2 |
Rep 1,073
Wow very nice and detail write up.
03-25-2013, 11:40 AM | #3 |
Ya ya ya, I am Lorde, ya ya!
266
Rep 2,772
Drives: E90 M3, 2015 SQ5
You forgot Step 10: Sell for $365.
nycplumber688.50 |
03-25-2013, 12:09 PM | #4 |
Rep 1,164
I have the IND tri-stich knob and E-brake. Very nice job! The threads you used looks a bit thicker than mine. Other than that, looks the same to me.
Akra GT4 / MS Stage 2 / MS UDP / BPM Tune / KW CS / H&R Sways / TMS Delrin / ST 380/355 BBK / Cantrell 2.5" Ducts / SR34 Pads / Apex Arc-8 / Hoosier R7's / Mode GT4 Splitter / GT4 Canards / APR GT-250 Wing / Cantrell Half Cage / Recaro Pro Racer / Schroth Profi II-6 / BMW Alcantera Wheel / Cool Shirt / ESS Fire Supp / Solo DL |
03-25-2013, 12:17 PM | #5 |
Rep 698
I'm taking orders at $50 and a case of New Castle.
Thanks. The threads I used are thicker. I did that on purpose to make it stand-out a little bit more.
03-25-2013, 03:36 PM | #7 |
Rep 344
I too have the IND tri-stich knob and E-brake boots. I agree I paid way too much for them. You did a really nice job. I do not have the skill nor the patience to accomplish something like this.
03-25-2013, 09:43 PM | #10 |
Rep 6,919
Nice work!
2022 Dravit/Fiona M3cx - Dinan midpipe w/VC, NW Carbonhaus CF, AST Springs, FC Spacers...more to come!
2016 Indi F80 M3 - SMB|Amaro | Mode Carbon | ESS | Akra EVO | KW HAS...SOLD 2012 MR e92 M3 DCT, ESS SC, Brembo BBK, BBS FI... GONE but not forgotten! 2008 AW e92 M3 6MT, ESS SC, BBS LM's...SOLD! |
03-26-2013, 07:05 AM | #11 |
Rep 1,318
Nicely done, I've been meaning to do this ever since I got the car but wanted to do it on spare parts first
I wonder what the seats would look like all done up in tri stitch I would also not use crazy glue, maybe 3m super90 |
03-26-2013, 09:24 AM | #12 |
Rep 147
Drives: '10 e92 m3
Looks sweet bro, great write-up!!
03-26-2013, 09:45 AM | #14 | |
Rep 6,919
+1, that price tag has been a bit of a deterrent. Granted it looks factory, but this isn't far off for a fraction of the cost and a little time.
11-01-2013, 12:29 AM | #15 |
Rep 698
I've gotten some feedback that people are interested so I'm bumping it back up.
11-01-2013, 10:17 AM | #16 | |
Rep 767
Someone needs to do a group buy on these.
2019 McLaren 720s / 2018 Lamborghini Huracan Performante / 2019 Porsche Macan Turbo / 2016 BMW M3/// IG @jon.hagerty
11-01-2013, 11:54 AM | #17 |
Rep 698
There are no marketing plans in the works, but maybe I will establish a "core" exchange program come Jan 1.
Now that it's fall, this is the perfect project to tackle while watching football on Sundays.
11-01-2013, 12:13 PM | #18 |
Rep 1,159
Maybe I can get my mom to do it for me lol, or my grandmother?
M3.E90 JZB Coded.GTSDCT.BomizValved.TurnerTestPipes.ResDelete .EurochargedTune.AAFilter.HRER40s
02-24-2014, 01:20 AM | #19 |
Rep 646
Drives: IG: khanhdom
still going to offer this?
11-06-2014, 01:53 AM | #22 |
23
Rep 139
I decided to take a crack at this tonight and wanted to share photos of my efforts. I recently installed an M5 shift knob/boot so I have the stock boot laying around for practice.
I started by picking out the thread for the job, which was harder than I expected. Matching the M colors was a bit tricky since I didn't have an official BMW pattern to compare against. It also didn't help that I was at Joanne Fabrics at 9pm and couldn't compare the thread in daylight. I picked an embroidery thread because it was thicker than the machine thread. The thinner threads didn't seem to give the right look. You stitch one bank in red, the other in light blue, and then the dark blue goes between those two. Dark blue doesn't thread through the boot itself at all. This is the pattern described by the OP, it's really quite simple. This view is from the inside of the boot, and the dashes represent what you're doing on the back (visible) side. If the holes are numbered from start (1) to finish (n) you're going 2, 1, 3, 2, 4, 3, 5, 4, etc. This is where I ended up after a short trial. The thread doesn't look bad, but it's thicker than I like so I'll be re-evaluating my options. I'll keep everyone posted. |
