      03-30-2014, 03:18 PM   #1
a7med606
a7med606's Avatar
Bahrain
41
Drives: 1 ///M + F80 M3
new transmission for my 1m
i had a small problem with my car transmission , the shifter was jerking in 3rd and it will engage only half the way in and when i release the clutch it will go in all , i took my car to bmw dealer and they said every thing is fine outside the transmission but maybe something inside the gear box so they are changing it under warranty and same thing for the clutch .
any one had same issue ?
bmw told me to drive slow for first 2000km for the break in period
should i drive slow or i can drive normal ?
      03-30-2014, 03:28 PM   #2
Dackelone
European Editor
Dackelone's Avatar
Germany
10589
Drives: N54 e82
You should be ok. Don't forget to get the trans fluid changed at 1,200 miles too. Hopefully that will be free as well.
I would also have them take a real close look at your rear main crankshaft seal. Many 1M's seem to suffer from a leaning crank seal. When it goes... so does your (new)clutch.
clutch, gear shift lever, transmission
