      08-27-2010, 11:00 AM   #1
southlight
Moderator / European Editor
southlight's Avatar
1537
Drives: X3M
Exclamation BMW 1M Coupe Partially Unveiled at Oktoberfest! [INFO, VIDEO & PHOTOS]
As speculated before, BMW shows more details of the upcoming 1-series M Coupé at the BMW CCA Oktoberfest today. Since not all 1-M enthusiasts can attend that event, BMW just published a new teaser video on m-power.com. Enjoy!
Unless you haven't already, make sure to register at http://www.m-power.com to have access to more information. Plenty of information and media from the BMWCCA Oktoberfest presentation can be found in an online Closed Room there over the next couple of days.
Follow our full 1M coverage here: http://www.bimmerpost.com/1m/
Screen captures:
Pics from
http://www.bimmerfile.com/2010/08/27...w-1m-revealed/
Pics from elfhearse:
INTERCOOLER showing ?????
Some more details per bimmerfile.com:
  • The color is Valencia Orange Metallic, a new color exclusive to the 1M
  • Update: The engine is N54 based (see Bimmerfile's reasoning here and SCOTT26's confirmation below)
  • The 1M will be manual transmission only
  • Those are the M3 Competition Package wheels
  • The front air intake is pretty similar to the M3's, but even more pronounced
  • The side skirts are also much like the M3's in shape
  • The side vents will be 'outrageous' compared to the other M cars
  • Some minor detail in the revealed area of the M1 will be changed. Bimmerfile suggests it's related to the headlights.
  • The rear valance will have vents above the exhaust that protrude out and are angled slightly inward (see here, courtesy of bimmerfile)
  • There's an oil-cooler in-front of the front left wheel (see here)
  • The rear-view mirrors will look very familiar to E9X M3 owners (see here)
N54 Engine Confirmed (per Scott26)
I see cars in the earlist stage but I have other projects to work on that I cannot afford to be distracted as I have many projects not only for cars but I also conceive stuff for BMWTV.de The German only BMW TV channel which in some cases do not involve cars. With each project now we have started to do Pre-visualisation on the computer because we can show it to the director and production crew and explain this is the angles we want to get the perfect shot.
The time window for this car is extremely tight and originally enthusiasm was not apparent until Dr. Kay Segler came to the M Division.
We had initially toyed with the idea of an 1M when we were conceiving the Coupe and did work with evaluation models then using the engine from the E46 and the upgraded E46 CSL engine but it proved to be too heavy for the car.
Originally in the early days of marketing the standard 135i was originally meant to be an M model.
The 1M that stands before you now has had possibly the most progressive stage from thought-production turnaround for a BMW. There had to be a lot of arm-twisting in the BMW Board because of the tight window between generation 1 and generation 2 of the Coupe. The proposal was greenlighted when BMW decided to use the Coupe model for the BMW eDrive evaluation. Therefore slightly extending it's life cycle.
When I first saw the car it was in a design studio as a full scale claymodel but since then some designers ideas have to make way for aerodynamics and engineering. The initial engine proposal was the N55 but they were having issues that cannot be solved within the time window. BMW Greenlit this car in July 09, now over a year later we see it as it intended , although testing still commences until the launch. Valvetronic was the main cause of the time delay but BMW have spent some time on this and are using the N55 as a basis for the next M3.
The best way to describe the engine of the 1M is a "Hybrid" but in the original form of Hybrid, nothing to do with "alternatives", but it is not a straightforward transplant.
There is a lot of this car that will carry over for the next generation 1M in which that car will switch to four cylinders to which the M Division engineers are already working on the basics without time constraints or restrictions. 1M (E82) is showing what is possible in a small timeframe 1M (F22) will show what is possible once you do not have restrictions.
Best regards,
south
Those forums...WHY NOT?
JOIN THE 6MT CLUB GROUP
      08-27-2010, 12:51 PM   #2
as7920
as7920's Avatar
597
Drives: 2023 SG/FR M4 xDrive Competiti
Unveiled. The Video
There is a closed room on the M-Power website with a locked video.
I am registered and logged in but can't access it yet!
http://www.m-power.com/_open/b/closedroom.jsp?lang=en
      08-27-2010, 12:54 PM   #3
Black Sheep
A Zip an a Double Cup
Black Sheep's Avatar
Drives: 2009 BMW 135i
o boy o boy
PTF Tuned | RB's | AMS FMIC | AR DP's | HPF Exhaust | CP-E DCI | Apex Arc 8's | 235/275 Star Specs |
      08-27-2010, 12:59 PM   #4
as7920
as7920's Avatar
597
How come I missed your post then South?
      08-27-2010, 01:06 PM   #5
jmunro
Drives: X6
Its like seeing a woman in a dress with her cleavage... such a tease!!
      08-27-2010, 01:07 PM   #6
eugegall
eugegall's Avatar
178
Drives: M4 CS
I just registered on the m-power website. I watched the little 20 sec video. It says for more to register at m-power. is there anymore?
      08-27-2010, 01:09 PM   #7
miro2296
miro2296's Avatar
Drives: '08 Montego Blue BMW 135i
HOLY SHIAT!!!! That looks bad a$$. Can't wait to see the rest!
BMW 135i/6 Speed/Montego Blue/Formula One Ceramic Tint/JB4 G4/AA Sport Intercooler/19 inch Iconz 880Z(19X8.5 & 19X10)/PSS 225/35 & 265/30/E93 M3 front sway bar/TRW front and rear Control Arms/BMS Drop In Filter/Dinan Exhaust/BlackLines/Upgraded \\\M RSFB
      08-27-2010, 01:10 PM   #8
twenzel
twenzel's Avatar
53
Drives: 15 Audi S3
      08-27-2010, 01:11 PM   #9
Crazy Bimmer
The Jesal
Crazy Bimmer's Avatar
Drives: E90 M3
2009 BMW M3  [0.00]
Damn maybe i should drive up there!
2009 E90 M3 - SOLD
      08-27-2010, 01:12 PM   #10
M_BYEEE
M_BYEEE's Avatar
Drives: BSM X5M
those wheels are sex and that front bumper looks like its gonna be super aggressive! Love the widebody
      08-27-2010, 01:13 PM   #11
Feyd
Feyd's Avatar
346
Drives: a DEEZZULL
Man... that's like really good side/under boob.
      08-27-2010, 01:19 PM   #12
RON1X
RON1X's Avatar
75
Drives: 991 C2S Guards Red
2008 E92 M3  [9.00]
can't wait to see the rest of the beast
991.1 C2S PDK, Guards Red | PDCC | Sport Chrono + | Clear Tail Lights | Alcantara Steering Wheel | HRE FF01 | TechArt Springs | Sport Exhaust
Previous: Porsche 997 Turbo 6MT, Atlas Gray | Cobb Stage 2 | HRE FF01 | Europipe Stg. 2 Exhaust | GMG LMS Rollbar | GT2 Exhaust Tips | Pagid RS-29 | Rennline Pedals | SSK
997.2 Track Car, heavily modded & E92 M3 DCT, still miss her daily & E92 335i heavily modded
      08-27-2010, 01:20 PM   #13
twenzel
twenzel's Avatar
53
Drives: 15 Audi S3
No hood bulge... you sure this isnt a 135is?
*hides* j/k guys!
      08-27-2010, 01:21 PM   #14
dmboone25
dmboone25's Avatar
4972
Drives: 2024 Golf R / 2022 718 Spyder
2007 E92 328i  [10.00]
2007 328i  [10.00]
Can't see the video at work!
But from the side shot above, it doesn't appear to have quads?
Not that I care--just an observation. The wheels look awesome, and the stance is wide and squat....
I like what I can see.
EDIT--Saw the video on my EVO--the car obviously has quads!
Past rides: 2016 981 BGTS, 2020 MINI JCW, 2017 F80, 2015 981 CS, 2014 F22 235, 2011 E82 135, 2008 E82 135, 2007 E92 328, 2007 E92 328 (My lady drives an OG M2. So does my dad)
      08-27-2010, 01:24 PM   #15
crex
Drives: bmw 135i, Jeep wrangler
quads shown in the video!
      08-27-2010, 01:25 PM   #16
southlight
southlight's Avatar
1537
Drives: X3M
There will be more soon.
It does have quads.
Best regards,
south
      08-27-2010, 01:25 PM   #17
TK-421
Registered Sex Offender
Drives: E46 M3 | 1JZ S13
It shows the quads in the vid
Stop putting stuff like painted reflectors and premium package in your signature. You're embarrassing.
      08-27-2010, 01:27 PM   #18
Jason
Administrator
Jason's Avatar
Drives: F80 M3
She's got quads alright!
Check on the Latest BMW News
Become a fan of Bimmerpost Facebook
Follow us on Bimmerpost Twitter
Subscribe to Bimmerpost Youtube Channel
      08-27-2010, 01:28 PM   #19
GBX
GBX's Avatar
Drives: 997.1 GT3
Attachment 423621
CSL style trunk? Looks possible from that image!!
      08-27-2010, 01:30 PM   #20
BrokenVert
Resident Kerbalnaut
BrokenVert's Avatar
Drives: Topless Brute/Hybrid Boogaloo
Tits. This car is gonna be awesome
      08-27-2010, 01:31 PM   #21
TK-421
the side profile shot shows that too. needless to say that along with the fender flares have got me pretty damn excited
      08-27-2010, 01:32 PM   #22
Jason
Administrator
Jason's Avatar
Drives: F80 M3
All along Scott has mentioned a "duckbill" type trunk
1-series m, 1m coupe, 1m debut, 1m forum, 1m unveil, 2011 1m, 2011 bmw 1m, 2011 bmw m1, 2011 m1, 2012 1m, 2012 bmw 1m, 2012 bmw m1, 2012 m1, 2013 1m, 2013 bmw 1m, 2013 bmw m1, 2013 m1, bmw 1m, bmw 1m forum, bmw m1, bmw m1 forum, bmw m1 info, m1 coupe, m1 forum, m1 info
